Hello everyone, I have a popup system that has one pipe in the middle surrounded by 6 other pipes that all feed into popup rotation valve thing(I have tried to google the name but coming up empty, please help). It doesn't work cause the gears inside are all busted and the result is that every popup is on at the same time.
There is no shut off valve for pop up system, so I'm wondering if there is any other way to disable it, I was thinking by plugging one of those pipes coming up from the ground might do it? But I have no idea how it works, I assume the water enters from the middle and is diverted to one of the six other pipes for the popups? does that sound right? Well any advice would be great, thank you.
