Thread: Which port is the Hi-Limit Sensor on Jandy LXI Gas Heater?
    Apr 2015
    Rosenberg/TX
    38
    "No need to mark this, I'll remember which is which.", I said before a myriad of distractions as I was taking the hi/lo sensors out for replacement.
    Now, of course, , I don't remember now which is Hi and which is Low. I *think* the port closest to the heater (the longer one if it matters) is High. Am I right?
    If I get them reversed will a hole open in the space-time continuum and the zombie apocalypse will start? Or will the heater just not work and I can just swap them and try again?
    Bill W
    12,500gal, inground gunite with iAqualink controls, Jandy variable-speed pump, and no longer using the Pentair chlorinator. Using Trouble-free for over a month and loving it!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Which port is the Hi-Limit Sensor on Jandy LXI Gas Heater?
    If it starts rhe apocalypse, we are going to hunt you down first Bill.
    Good luck on your issue. Hopefully a bump will get you an answer.
    Essential Links:
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    They are both called high limit sensors and one is 20 degrees higher than the other. The one closer to the heater is the 130 degree sensor and the other is the 150 degree sensor from what I recall.
    No, no hole will open in the space-time continuum. The zombie apocalypse has already started.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
