Thread: Coleman lay z spa heater pump
    May 2017
    portland oregon
    2
    Morning folks. Simple problem but google is no help. I've got a 1.5 year old Coleman inflatable lay z spa and the heater pump is very noisy. I disassembled the 'egg' and pulled the pump out. The impeller body that sits on the shaft in the motor housing is cracked and full of water. Coleman/Bestway is no help whatsoever and the only 'spare part' I can purchase is a new egg. Seems excessive and expensive for what is basically a $10 impeller part. However google is proving useless as Bestway has these things on lockdown and i'm getting nowhere trying to source the pump or impeller. please anybody have any bright ideas?
    thank you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Coleman lay z spa heater pump
    Welcome to TFP Broncos!
    Good luck, and enjoy the forum.
    Essential Links:
    May 2017
    portland oregon
    2
    Quote Originally Posted by Patrick_B View Post
    Dang got my hopes up there
    thank you
    sanjosse's Avatar
    Sep 2017
    San Jose/CA
    2
    Quote Originally Posted by broncos730 View Post
    Hi broncos730,
    I also have a 2016 Coleman Lay-Z-Spa that the pump/heater just stopped working. I haven't had a chance to diagnose it. But if it has the same impeller body problem, I believe I can replicate the part and have it printed at Shapeways.com. I've used SketchUp Pro and created other parts as shown here (https://www.shapeways.com/designer/sanjosse/creations). I would need an impeller body to get the measurements exact, any donors?
    Sincerely
    sanjosse
    sanjosse's Avatar
    Sep 2017
    San Jose/CA
    2
    double-post. sorry
