Thread: Liquid reagent compatibility
    Mattsway's Avatar
    Apr 2017
    Sussex UK
    30
    Does anyone know whether the LaMotte DPD liquid reagent 1B, order code P6741G for their ColorQ Pro 7;
    https://www.amazon.com/LaMotte-Color.../dp/B003MB678I
    Is the same as Taylor R0871C?
    I bought the Taylor kit from the your side of the pond, but LaMotte refills are more cheaply available this side, in UK.
    Thanks.
    In ground hydrotherapy pool in wooden cabin. Oil heater for water temp 89f. Poly Bloc construction using high temp liner. 9'9" square x 3'8" deep, 2700 gallons. Hayward MaxFlo XL pump, model SP2310XE161 0.97hp. Waterco Multicyclone 12 Plus Centrifugal Filter, guage reads 16psi. Certikin Skimmer with floating collar Weir. Spectrum UV light, Calorex 33 dehumidifier and 2 radiators in cabin. Taylor K2006C test kit.
    40,877
    Re: Liquid reagent compatibility
    Generally I would not think the reagents are compatible across brands.
    Might try to contact LaMotte and see what they say.
    JoyfulNoise's Avatar
    May 2015
    14,085
    That's not powder, it's a liquid reagent. It would be more similar to Taylor's R-0001/R-0002 reagents. It doesn't create a solution with a lot of excess DPD in it like the powder does and so you can easily bleach-out a high FC sample. It can typically be titrated with the R-0871 but you have to add enough of the liquid drops to ensure that you are measuring all of the FC properly.
    Matt
