Thread: Solar power to circulate water on slide
    May 2012
    Jackson/New Jersey
    43
    Been toying with this idea for a a few years. Pretty much given up due to cost. Instead of solar powering a DC pump to run water down slide, do you think a 12v deep cycle battery, wired to pump and use a solar panel to charge the battery. An on\off switch to only circulate water when in use....
    Do you think this world work?
    any advice would be appreciated...
    Brian
    25,000 gallon, in-ground, vinyl liner
    Hayward S244T sand filter
    Hayward super-pump 1.5 Horse
    Hayward Aquarite SWG
    Pool construction 1999
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Solar power to circulate water on slide
    Why not use your pool pump and divert some of the return flow to the slide? A DC battery system is a lot of extra work and expenses when you already have a pump ready to go.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2012
    Jackson/New Jersey
    43
    because I would have to dig about 30 feet and 7 under concrete....
    Thanks for the reply!
    Brian
    40,879
    I just use fresh water for my slide, it really does not need much water and tops off all the splash out
