Thread: Pool Chlorine Online?
    May 2017
    Fresno, CA
    37
    What type/brand of chlorine should I buy and where to get the best deal? Online? I just ordered my TF-100 tester : )
    Thanks!
    Bestway AG Vinyl Oval
    18' x 9' x 48" ~ 3,548 Gallons
    Sand Filter & Solar Heater
    Elite Spa 86" x 87" ~ 350 Gallons
    TF-100 Test Kit
    40,848
    Re: Pool Chlorine Online?
    You should not buy any chlorine online. You should be using liquid chlorine which would be prohibitively high cost to ship.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Donldson's Avatar
    NW Ohio
    3,211
    Liquid chlorine weighs 8 lbs a gallon so shipping it in anything less than pallet quantities is not going to happen. Since you are in California if you can find a HASA dealer with returnable liquid chlorine totes that might be your best price.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Mar 2008
    Los Angeles, Ca
    252
    I use bleach from Costco or Chlorine from Home Depot.
    If buying from HD, check the date of manufacture on the box, get fresh chlorine only because they store it outside which degrades it.
    Date is a code with days (001 to 365) and year
    25,000 gal fiberglass pool, Raypak 336k BTU low nox RP 2100 gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump, diy control and automation system
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater, diy control and automation system
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Start here: http://www.hasapool.com/dealer_locator_hasa.php
    You'll pay a deposit on the crate and jugs, but after that it's usually cheapest and the stuff is fresh
    Also watch the sales. OSH usually has a big sale on pool chlorine. Check the date codes before you buy. It'll be stamped on the case somewhere. Chlorine Date Code Decoder/Easy Way to Measure Strength.
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    OSH just had a sale on KemTek 10% pool chlorine last week. Two gallons for $4.99! I had to dig through two hole pallet stacks to find fresh product though. They had some with a date code of Jan 3rd.
    Fortunately I found some with April 2nd, so not too old.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
