Thread: Hayward blue essence trouble
    May 2017
    Titusville fl
    1
    I have a Hayward blue essence salt chlorinator that is just over a year old. Today I found it with no display and no light. Seems it's totally without power. I tested the breaker and the wires coming attached to the board and it's good. The fuse is good but there is no power at the fuse that I can tell. Is there someway to narrow down the culprit? Any help appreciated.
    Jun 2011
    Long Beach, CA
    2,892
    Re: Hayward blue essence trouble
    Welcome to TFP!
    Turn off the SWG and remove the board for the display and reinstall it. Sometimes this helps when there is a bad connection.
    Oct 2007
    Parkland, FL
    753
    I believe they have 3 year warranties? Certainly more than a year I believe. I had my friend install that model about a year ago.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
