Results 1 to 10 of 10
Thread: What chemicals do I really need
    Apr 2017
    Elkhart, IN
    12
    I see a lot of chemicals listed in the pool math calculator but which ones do people use with regularity?
    Bleach (or liquid chlorine)
    Borate
    Baking Soda
    Calcium Chloride
    Calcium Chloride Dihydrate
    Stabilizer
    Muriatic Acid
    Dry Acid
    21,000 gallon, In Ground, Vinyl
    Pentair Clean & Clear Plus Cartridge Filter 420 Sq. Ft. (Switched from sand filter in May of 2017)
    Waterway Champion 56 Frame 1hp Pool Pump
    Using TF-100 Start Up XL - Pool filled from well in 2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,309
    Re: What chemicals do I really need
    All I ever add is 12.5% bleach, 31.45% Muriatic Acid, and Trichlor pucks during vacations.
    Apr 2017
    Elkhart, IN
    12
    So you don't worry about CYA or TA
    40,878
    What is the status of your water? Test results?
    We generally do not recommend buying anything until you know if you need it ... and you know if you need it by testing the water with one of the recommended test kits
    Richard320's Avatar
    Jan 2010
    20,309
    Quote Originally Posted by firstplacetrophy View Post
    My pool has enough CYA in it since it doesn't evaporate out and the pucks replenish what splashes out. My tap water is hard enough to maintain the TA without having to purchase baking soda.
    Apr 2017
    Elkhart, IN
    12
    No test results yet, I just received the TF-100 yesterday and I'm not opening the pool for another few weeks. Just curious of the chemical I should keep in stocked at all times.
    40,878
    The only thing you currently know you will always need is chlorine.
    Everything else depends on the test results.
    Richard320's Avatar
    Jan 2010
    20,309
    The only thing you can be certain of is bleach, but that has a shelf life, so there's no point in buying up a truckload because it will deteriorate over time and leave you with some expensive salt water.
    Apr 2017
    Elkhart, IN
    12
    Sounds good, I'm picking up 20 bottles of chlorine tonight ($1.50 per 12.5% bottle at Menards if anyone has a Menards nearby)
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    Rarely have I used anything listed above in your list except bleach (when I want instant rise in FC, the SWG works slowly) and muriatic acid for pH and even that is pretty rarely needed in my pool.
    I added calcium once in 5 years but you have a vinyl pool and don't need to worry about it.
    The only things I would suggest keeping on hand is bleach and Muriatic Acid (only one jug, never stored near metals or bleach). Then depending on your own test results you can buy anything else as needed and not deal with having to store it.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
