Thread: TA and PH swings
    Trifive's Avatar
    Mar 2017
    Spring, TX
    15
    TA and PH swings
    So I have a fairly new pool and the PH is high (8.0 or so) everyday when I test it. So add enough MA to bring it down to 7.4 or so and then next day back up to 8.0. Pool builder said I'll be chasing this for a good 6 months but didn't say why. My TA was 80-120 up until about two weeks ago when I tested and it was 60. So I added baking soda. That brought it up to 80...but then the PH went high so I added MA and then that brought both down. How do I get out of this yo-yo effect with PH and TA as I try to raise one but lower the other?! All my other readings are all within normal range per TFP standards and I have zero water issues as the water is crystal clear. Thanks for any info!
    FC=4.4
    TA=60
    PH=7.6
    CH=280
    CYA=30
    13,700 gallon, IG plaster pool/spa, cartridge filter, 2 sheer descents by Anthony and Sylvan. BBB method. Stenner pump for chlorine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: TA and PH swings
    Leave the TA lower.
    Also, you'll be dealing with rising pH for a while just from curing plaster.
    Trifive's Avatar
    Mar 2017
    Spring, TX
    15
    Leave the TA lower.
    So TA being around 60 is no problem?
    Richard320's Avatar
    Jan 2010
    20,296
    Quote Originally Posted by Trifive View Post
    Not at all. That's where I run mine.
    Plug your numbers into poolmath and check the CSI calculation at the bottom. You might decide to target 7.4 or 7.5 when you add acid, just to keep CSI in the +/- 0.5 range.
