Thread: Special steps to replace corroded Niche ring?
    Sep 2010
    Winnipeg, MB
    5
    My Niche ring has corroded due to poor water balance a few years back. I bought a replacement ring for my inground Pentair wet niche (Ring).
    I'm just wondering about the removal and insertion of the 10 screws that hold it. Is this a repair I should do dry or is it ok to do under water?
    Just worried about the water being forced through the holes and getting behind the pool wall and liner.
    Any guidance appreciated.
    Ed.
    Pool: 16x32 inground (2011) Experience: Some - With a previous above ground, learning with my brandnew pool
    Re: Special steps to replace corroded Niche ring?
    First, you have to pull out the light. Disconnect at junction box, tie string on cord and pull through.
    The ring can be replaced under water, but there's always some risk of things going wrong.
    Support the site
    Sep 2010
    Winnipeg, MB
    5
    Thanks James! I totally wasn't thinking I'd have to pull the light out, but I obviously will to get the new ring in place. The job got bigger but you saved me the last minute panic on needing to re-run the light.
