Thread: Specific Question Regarding TFP CH Test...
    Apr 2017
    OC, California
    8
    Greetings all:
    While doing my CH testing, I'm getting wildly different results based on whether or not I stir my sample during the the last step of the testing.
    The instructions say: "Add R-0012 one drop at a time until the color changes to blue. Multiply the number of drops x 25" My question is, should I be stirring my sample (either constantly, or after each drop) while adding the R-0012 reagent?
    If I DO stir, I'm getting a CH reading of around 175 PPM. If I don't stir, it's closer to 375 PPM - quite the disparity in results...and one that could potentially have me make a significant error regarding chem additions.
    So....to stir, or not to stir...?
    Any and all help would be appreciated!
    18,400 G Kidney Shaped IG PebbleTec pool w/600 gallon attached spa & associated overflow
    Pentair VS DC Pump; Pentair DE Filter, Jandy/Laars Heater, Hayward AquaRite 900 series SWG (new addition...)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,302
    Re: Specific Question Regarding TFP CH Test...
    Constant stirring.
    I do mine with the speedstir. When I switched from manual swirling to speedstir, my CH value dropped 1/3!
    A speedstir would make a wonderful Father's Day gift
    JoyfulNoise's Avatar
    May 2015
    14,085
    Get a SpeedStir, it's the best way to do testing.
    Yes, you need to continuously agitate the solution by stirring. Few people have the skill to swirl with one hand while adding titrant with the other, so getting a SpeedStir improves the testing greatly.
    Also, make sure you are reaching the proper endpoint. The test ends when the blue color stops getting more blue, NOT when you first see the blue color. This is typically 2-3 drops beyond when you first notice the blue color. Many people make the mistake of ending the test at the first sight of blue and that leads to variations in drop count.
    Matt
    Apr 2017
    OC, California
    8
    Constant stirring.
    Thanks for the fast reply!
    A speedstir is exactly what I use...which, unfortunately, leads to more confusion for me. I just looked at my Municipal Water District's annual water quality report for 2015 (2016 hasn't been issued, yet) and it says that the CaCO3 levels here (Orange County, CA) should be around 330 PPM.
    So...what gives? Bad reagent?
    I'm setting up a new SWG - I'm trying to dial this thing in before turning it on and this is vexing me....
    AHHHHHHH....THAT may be the ticket.
    Off to test again!!!
    Richard320's Avatar
    Jan 2010
    20,302
    Trust your testing. Water quality can vary throughout the year depending on the source. If right now they're pulling a lot of snowmelt from rivers and reservoirs, it's going to be softer than if it was pumped from a well.
    Apr 2017
    OC, California
    8
    Yep. That was it. I'm now getting repeatable results right at 350 PPM - right in line with what I'd expect them to be, given my experience with water hardness in Orange County.
    I'm really glad I asked. I can't even find calcium chloride here - when I asked the guy in the pool/garden section of Home Depot, he said, "wait, you want to ADD hardness to your water?" That gave me enough pause to go back, retest, and ask for help!
    Anyway.
    Thanks a ton to both JoyfulNoise and Richard320 for your help!!!
