Thread: Fizzy water - is there something "off" in my water?
    I can't remember other pools "fizzing" when kids jump in - does that mean our pool has something wrong in the chemistry?
    The numbers are almost always this:
    FC b/t 2 - 3
    CYA b/t 30-40
    pH b/t 7.2-7.5
    TA b/t 70-80
    Thanks!!
    Cheryl
    21x41x54" AG Artesian Seville II
    Installed around 2004 - we moved here in 2008
    23,000 gal
    Hayward SwimPro 256T Sand Filter
    1HP 2speed Hayward Power Flo Matrix
    (and have 2HP Hayward Swimpro and a 2hp 2speed Waterway Hi-Flo pump as back up also!! lol)
    No heating - other than Solar SunRings
    Central IL
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Fizzy water - is there something "off" in my water?
    sounds like algaecide. what are you using to test? strips? you're brushing the edge of the chlorine/cya chart with those levels, especially if you aren't real sure what they are.
    Butterfly's Avatar
    South Carolina
    10,045
    It does sound like algacide, but we really need a full set of test results
    FC
    CC
    pH
    TA
    CH
    CYA
    And, as reebok asked, it would be good to know what test kit are you using.
    You're done SLAMing when:
    I don't think it can be algeacide, because I've never used the first drop of it. We replaced the liner, and all I've used since then is ph+, stabilizer/conditioner, alkalinity plus (all left over from last year) and 6% bleach.
    I use the TF-100 test kit. The numbers I had posted below are the range that I get basically every time I test the water - the only thing that really moves is the chlorine.
    My numbers on the latest "full" test were:
    FC 3.5 (which is higher than typical - I must have just added chlorine? I can't remember)
    CC .5
    pH 7.5
    TA 80
    CH (don't test this)
    CYA b/t 30 and 40 on the cylinder when I can't see the black dot
    Thanks again for your help!
    23,000 gal
    Central IL
    I would raise your FC level up a little extra high. That will help break down any organic foaming agents that might be in the water.
