Thread: strength in Chlorometric degrees
    Apr 2017
    Belgium
    16
    Hi !
    I would like to know with a little more depth what strength is the chlorine I add to my pool.
    I live in Belgium and they display the strength of the chlorine in degrees () as shown here :
    http://www.forever-products.com/medi...l_18_5L_BD.png
    They also sell 50 strength in a 25L container.
    After some research it appears that this corresponds to Chlorometric degrees, which are about 3.15 times the weight percentage of available chlorine, which can be converted to available NaOCl using the molar masses ratios.
    To then convert that to trade percentages, which is what is needed for poolMath, I need the specific gravity of the bleach. As I understand it, this value depends on the production process of the chlorine, and is representative of the quality (lye content)?
    Can anyone tell me if I'm on the right track, and if there exists an easy way to estimate the specific gravity of 50 (=15.09% by weight of NaOCl) chlorine ?
    I'm also trying to figure out ChemGeek's PoolEquations spreadsheet, and I'm trying to adapt the levels to fit my bleach concentration. So any help is welcome
    Thanks !
    7.25k gallons IGP, vinyl, sand filter, solar heater (manually operated)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,905
    Re: strength in Chlorometric degrees
    Where is Matt when you need him.....
    Support the site
    50 Chlorometric degrees is 15.85 % (Trade percent). When you enter the percentage in the calculator, it automatically changes to trade percent for any value over 9.0%.
    If you're using 50 chlorometric, enter 15.85 in the percentage and it will work.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    14,094
    Sorry. Busy morning. JamesW nailed it right. The conversion is 1 CD = 3.17gram/liter free chlorine.
    As for Richard's spreadsheet, you'll have to email him directly about it as it is not a tool TFP uses regularly (too complex for the novice user). A
    Matt
    May 2014
    Franklin, NC
    9,905
    Quote Originally Posted by JamesW View Post
    Thanks James!!!!
    Support the site
    Apr 2017
    Belgium
    16
    Oh I see where I got it wrong, I (mis)read somewhere that it was 1 CD = 3.17 gram/Kg, or 0.317 % by weight. I think that's where my confusion about specific gravity comes from.
    Thanks a lot !
