Results 1 to 11 of 11
Thread: Well, the worst just happened...
    Jun 2016
    Monterrey, Mexico
    34
    Couldn't find a specific forum for this. Mods feel free to move.
    Big hail storm yesterday. 3 hours of downpour and my garden couldn't take it, it got flooded and grad, dirt and tons of leaves went into the pool.
    It is dark grey.
    I had to use flocculant to settle it down.
    Lets see how it goes tomorrow.
    Vaccuming will be a monumental job because of the leaves. My vacuum line has a valve check and it got obstructed in two secs
    11'x21'x4.4'
    7.0K IG Concrete pool
    Hayward Swimpro 19" Sand Filter
    1HP pump
    Pentair Intellibrite 5G 500W equivalent white light
    40,893
    Re: Well, the worst just happened...
    No one ever HAS TO use flocculent. Hopefully it works out for you and doesn't make a bigger mess that you have to deal with inside of your filter.
    You should use a leaf rake to manually remove as many of the leaves as possible before you vacuum.
    Jul 2014
    Sacramento, CA
    243
    If you believe the leaves have settled to the bottom, might be worth dragging a leaf rake across the floor of the pool to get as many as you can. 10 minutes of that could save a lot of vacuum obstruction clearing. For floor raking I like the cheapo kind like this one, with a thin lip that you can drag or push across the bottom.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Jan 2017
    Monterrey, NL, Mexico
    492
    Muy buena la granizada de anoche!!
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Jun 2016
    Monterrey, Mexico
    34
    De a madre!!!
    Thanks guys. I'll buy a leaf rake tomorrow morning and vacuum afterwards
    i know i don't HAVE TO use flocculant but thought it could speed up the process. I'll be vacuuming to waste to avoid filter damage.
    Electricity is not cheap in Mexico and although I have solar panels I decided to vacuum a couple of times to have a clear pool this weekend instead of 5 days of filtering.
    I also shocked the pool to avoid algae or bacteria from the flood. Better to prevent.
    11'x21'x4.4'
    1HP pump
    40,893
    Review the SLAM process we teach. Not sure what you meant by "shocked" but we do not suggest 1 time massive chlorine additions if that is what you did.
    Apr 2017
    Phoenix
    500
    In addition to leaf rake, you may want to get one of these cheap yet effective devices.
    Poolmaster 28300 Big Sucker Pool Leaf Vacuum and Bag with High Pressure Water Jets and Multi Directional Wheels - Classic Collection https://www.amazon.com/dp/B0007PZN9Q..._tpgdzbSAG3D9K
    They use the garden hose to create suction to shoot the leaves in a bag. I find this device is easier for a large load of leaves, then use my leaf rake when I get a few leaves at the bottom.
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
    Jun 2016
    Monterrey, Mexico
    34
    I did mean the SHOCK part of the SLAM process as the first step and to avoid bacteria or algae growth from this bad situation.
    obviously I'll be following all due to the conditions of the pool.
    spinPHD, thanks for the leave sucker advice, I'd be looking into that
    11'x21'x4.4'
    1HP pump
    Oct 2016
    Phoenix
    203
    I went through the same thing a few years ago. It took about 1 week to get it looking good again. No big deal except for backwashing the sand filter about every 1/2 hour for the first day. I had a thick layer of silt settle on the bottom. After taking care of what was on the surface I let my suction side cleaner drive around and take care of the fine mud that settled.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    Jun 2016
    Monterrey, Mexico
    34
    I know we try to be purists, but sometimes a vegan needs a big burger
    flocculant worked as expected
    vacuum to waste. Minimal loss of water
    pool at 85%
    thanks all
    11'x21'x4.4'
    1HP pump
    Jan 2017
    492
    Excelente!
    Felipe
