Thread: First Results with TF-100
    Jun 2015
    Las Vegas,NV
    16
    So the pool is now 3 weeks old, and my TF-100 just got here. Here's my first set of results.
    pH 7.6
    FC 6.0
    CC 0.0
    TA 120
    CH 475
    CYA 50
    That's the result of the extremely hard water in Las Vegas. My next move would be to drop the TA down. But where do you recommend to drop it to with the crazy hard water here? I also read in another post to make sure pH never goes above 7.8. With the quartz still curing the pool is just eating Muriatic right now. Hmmmmmm, do I see IntellipH or a Stenner in my future.
    The SWG will go online in another week.
    Thanks
    Drew
    12K Gallon Quartz IG Pool & Spa, Waterfall with 1.5 HP Whisperflo , Easytouch 4, SWG IC40, 3HP IntelliFlo VS, Screenlogic 2, MasterTemp 400K, TF-100
    40,848
    Re: First Results with TF-100
    Those numbers look fine. There is no need to actively worry about the TA. As you keep the pH in range the TA will drop slowly on its own.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Drew,
    Those numbers look good to me also...
    With a new pool you will be fighting increasing pH for a while, but I see you have a spillover spa and waterfall. What a lot of new pool owners don't understand is that running your water feature also increases pH.
    In fact, that is exactly how we go about lowering TA. We add Muriatic Acid, which lowers TA and pH, and then aerate like crazy which brings pH back up to what we want.
    As far as never letting your pH get above 7.8.. It is on the upper limit, but you will find that most SWCG pools like a pH of 7.8.. In my case, my pool will stay at 7.8 for a couple of weeks, or more, without adding any acid. But it will stay at 7.6 for only a few seconds...
    Good luck with your new pool,
    Jim R
