Results 1 to 20 of 20
Thread: Muriatic acid cost?
    Jan 2017
    Charlotte, NC
    37
    Muriatic acid cost?
    How much are you paying for muriatic acid? I pay around $8 a gallon at Lowes. Seems high!
    Pool completed December 2016, Pebble Tec, ~14k gallons, SWG, Jandy Pro-Series variable speed pump, cartridge filter, heater, iAqua Link
    40,851
    Re: Muriatic acid cost?
    I think the pool store around here has the 31% strength for about $12 for 2 gallons.
    There is another store that sells it in bulk (4 1 gallon jugs) for cheaper than that, I think about $20.
    Mar 2016
    NC
    31
    Home Depot has 2 gallons for $10
    15K gal, IG plaster, 2 Jandy variable speed pumps (1 for filtration and 1 for spa returns/spillover), Jandy CL Cartridge filter, Delta UV, Jandy gas heater, Rola-Chem for chlorine and acid; pool build completed June 2016
    40,851
    Quote Originally Posted by bmsm6 View Post
    Make sure it is not the 1/2 strength ...
    Sep 2016
    ND
    125
    Just went through this last week...Our local Home Depot only has the "Green" version, which is around 20%. Our local Lowes has the Green (20%) and the regular (31%), the latter was about $8/gallon. Menards has both as well, and their 31% was $6/gallon, however they were sold out (and why I ended up at Lowes).
    Derek - November 2016 Build, Fill, Cover, and Close. Starting Equipment for the first time in Spring 2017: 26K IG 20x40 Vinyl, All Pentair: IntelliFlo VST 2, Clean and Clear 420 Cartridge Filter, EasyTouch 8, IntelliChem, IntelliChlor IC60 SWG, MasterTemp 250K NG Heater, GloBrite LED lights, Autelis Automation Integration, CoverStar Leading Edge Automatic Cover, Dolphin Quantum Robotic Cleaner, Interfab G-Force 2 slide, Interfab T7 diving board
    Mar 2015
    MO
    86
    4.99 at Menards.
    In Ground Pool, ~40k gallons, Pebble Tech, Intelliflo iQ60 SWG, RayPak 406 Gas Heater, Sand Filter, Variable Speed pump, seems to get alot of sun, but no debri. built in 2006. TFT XL Test Kit, with SpeedStir. Water from hose March.2017 used to fill FC=0, pH=7.2, CH= 375-400, TA=240.
    May 2016
    Troy IL
    484
    3.99/gallon at Rural King is the cheapest I've found. Second cheapest is 4.99 at Menards. Lowes and Home Depot near me only carry that green half strength stuff, which I don't personally care for.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Jun 2015
    Las Vegas,NV
    16
    In the Southwest markets Lowe's and Home Depot only carry 14.5%. When they switched from 29% to 14.5% they never lowered the price. They continued to sell the half concentration at the same price as before. I get my 29% or 31% at Leslie's.
    12K Gallon Quartz IG Pool & Spa, Waterfall with 1.5 HP Whisperflo , Easytouch 4, SWG IC40, 3HP IntelliFlo VS, Screenlogic 2, MasterTemp 400K, TF-100
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    489
    In Florida I get it at Home Depot a little over $11 for 2 gallons. I'm using less these days after implementing some recommendations from others here such as letting my TA drop to 50 and holding the pH around 7.7. I use about 12 oz twice per week now.
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I pay 5.10 at my supplier.
    Essential Links:
    MNiels's Avatar
    Mar 2016
    Seminole County, Central Florida
    18
    I pay $4.50 per gallon of 31% at our local independent pool shop, Bud Mudd's, in Winter Park. Same price for a long time!
    Vintage pool, 1967. Inground, 23k gal, 38'x18', 3.5'-8' deep, no frills, screen-enclosed. Refurbished 2016: Pentair CC150 cartridge filter, WetEdge PearlMatrix Pebble; porcelain waterline tile; Hayward skimmer SP1070. Pentair/Sta-rite SuperMax VS 1.5 HP pump (6/2017). City water, no restrictions. TFPC, chlorine bleach, TF100, SpeedStir.
    Jun 2016
    Bentonville, AR
    16
    If you have at Atwood's near by, they have 20 baume 31% acid on sale for 2.99.
    http://www.atwoods.com/liquid/kik-in...acid-1-gal.htm
    22000 gallon IG Plaster, Pentair CC-150 cartridge filter, Pentair Intelliflo 2 VST pump, Pentair Rebel Suction side cleaner, city water, 2016 build
    May 2016
    Troy IL
    484
    Quote Originally Posted by Razrbak View Post
    Dang
    That is the cheapest per gallon I've ever seen. I was pretty proud of my 3.99 find at Rural King. I don't have an Atwoods near me though, so I'll keep paying $4.
    FLPoolDIY's Avatar
    Aug 2016
    Land O Lakes, FL
    102
    This is the one item that is cheaper for me at the Pool $tore. I live in FL and use one of the chain stores (Pi*ch A Pen*y).
    I pay about $5.00 per gallon. Lowes is about $.50 more per gallon.
    FL, 15K gal (15x30 rectangle beach entry), IG Plaster, 2010, 1 skimmer, 4 returns, ecostar VSP, Pro Clean (PCCF-125) cartridge filter, IC20 SWG, Hayward Navigator floor suction cleaner, solar heat, waterfall, 2 lion head spouts, 1hp pump, TF-100 w/SpeedStir
    7.89 at Lowes. Just left there.
    Jun 2015
    Las Vegas,NV
    16
    Quote Originally Posted by Thinkly View Post
    What % and also where at?
    Thanks
    Mar 2016
    NC
    31
    The ones I get at Home Depot are 31.45%. 2 gallons for $10.
    Jan 2017
    Charlotte, NC
    37
    Well darn, I've been using the Green kind from Lowes. I had no idea it was a lower %.
    frbruno64's Avatar
    Jun 2015
    Berwyn, PA (Philadelphia suburb)
    20
    Philadelphia suburbs. Two gallons (31.45%) for $14.49. Looks like I need to shop around for a better price.
    33k, IG Pebble, 1.5hp Challenger, Pentair FNS, TF-100
  20. Back To Top    #20
    Jan 2017
    Charlotte, NC
    37
    None of the Home Depots within 100 miles of me sell the 2-pack. So check before you go.
