Results 1 to 8 of 8
Thread: Bad muriatic acid? Added gallon still high ph.
    I added a gallon of Muriatic acid and my pH is still reading 8.2 which means it is presumably higher.
    The pool calculator only goes to 8.6. Does that mean that is as high as my pH could be? If so according to the calculator I shouldn't have had to add that much to go from 8.6 to 7.5.
    My muriatic acid was a couple years old and I've read that it doesn't "expire" so what gives?
    BTW my FC is 5 and my CYA is ~40.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Mar 2016
    Gilbert AZ
    45
    Re: Bad muriatic acid? Added gallon still high ph.
    I've had really weak batches of Acid...maybe your PH was sky high + weak acid?
    Just add more let it mix and retest....repeat until you are good.
    *EDIT
    Also make sure whatever your using to measure the PH is accurate...if using drops make sure they aren't expired.
    11,507 Gallons | In Ground Pebble Tec | QC XHP In Ground Cleaning System | System 3 MM Sta-Rite Filter | Pentair VS-T 3050 Pump | Pentair Ultra Temp 120 H/C | QuickPure 3 Ozone | K2006 Test Kit
    Mar 2017
    Villa Park/California
    19
    Do you know what strength it is? I purchased several bottles from Home Depot before realizing it was only 14.5%. A gallon of that stuff barely dented my pH and TA when it was high. Now I buy the HASA stuff from a local pool store. I think it is 31.5% and a much better value.
    18,000ish gallon outdoor gunite pool & small spa (built in 1970s, re-plastered at least once)
    3HP Pentair Inteleflo VS Pump-011018; Waterway Crystal Water/Aqua Clean Cartridge Filter 570-425; Rheem 267A Gas Heater; Taylor K-2006 for pool chemistry testing
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Your pH could be much higher than the tester is capable of reading. And pH is logarithmic. The jump from 8.0 to 9.0 pH is ten times larger than the jump from 7.0 to 8.0. Just keep dosing with Now as 8.2 and eventually you'll get a shift. Once you're below the limit of the testblock, things should behave.
    A good doublecheck is to compare your readings with what Effects of Adding Chemicals (bottom of poolmath) says about TA reduction for a given amount of acid. The pH calculation will be so far off you should try to not even read it but the TA drop is usually right on.
    And also, if that acid is marked anywhere as "low-fuming" or "Safe" it is watered down.
    What's your TA?
    Support the site
    It was the full strength muriatic acid I can guarantee that. I haven't measured TA mainly because I know the well water I filled my pool with has high TA and I didn't want to waste the drops.
    My assumption was that continuing to drop pH would naturally drop TA. Sounds like a trip to Lowes for a new gallon or two of muriatic acid is likely the answer:
    Also I've used two different test kits to test so the reagent isn't bad. One is brand new.
    You need to enter the TA into the calculator for the calculator to calculate the correct amount of acid to use to lower the ph.
    If you’re waiting 24 hours to retest, the pH might have gone back up due to the high TA.
    When adding acid, make sure the pump is on and brush the pool after adding the acid.
    Retest after about 30 minutes after thoroughly brushing the pool.
    Also, until the TA is correct, you should be lowering the pH to 7.2 each time.
    Support the site
    TAis 220. High as I suspected. Added acid to reduce pH to7.2. I'll test again later. I didn't have time to brush but will do that if I have to add more.Thanks.
