Results 1 to 16 of 16
Thread: New leaf net
    Jan 2016
    Sonora, California
    147
    New leaf net
    I have this leaf net now and it works well but it needs to be replaced. Should I get the same or do you all suggest something else?
    https://www.amazon.com/Fibropro-Prof...f+pool+skimmer
    Under Construction - Free form in-ground pool/spa, 24x42, 815 sq ft, 119' perimeter, 3.5-8 ft depth, 26,500 gallons, Triton II sand filter, IntelliChlor SWG, 3 Intellibrite LED lights, IntelliFlo VS pump, Easy Touch Control System, raised planter box & patio space TBD........
    Jan 2012
    'burbs of Augusta, Georgia
    8,594
    Re: New leaf net
    That's a nice looking leaf catcher! If that one has been working for you I'd stick with it. It has a nice flat surface for the bottom of the pool to catch things, and a big net so you don't have to keep emptying.
    Not a bad price either.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: New leaf net
    It says lifetime warranty! Make 'em send you a new one.
    Jan 2016
    Sonora, California
    147
    Re: New leaf net
    Not sure if the warranty covers a puppy, lol.
    Jan 2012
    8,594
    Re: New leaf net
    Quote Originally Posted by Eyetattoo View Post
    Sent from my SM-G930V using Tapatalk
    uhh..yeah... that might be the *one* exclusion
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,023
    Re: New leaf net
    I wanna see the puppy!!!
    Yeah I don't think I would even ask for a replacement after a "land shark" got a hold of it
    Kim
    Houston, TX
    1,304
    Re: New leaf net
    speaking of puppies w big puppy breath - this one, Bear, almost ate a net
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jul 2012
    Tallahassee, FL
    34,023
    Re: New leaf net
    PUPPY!!! yeah nothing is safe when they are in this stage!
    Oct 2016
    Phoenix
    204
    Re: New leaf net
    I use the same one and like it a lot. It helps that I got two of them for $10 each at a clearance sale.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    buddywiser's Avatar
    Morgantown, WV
    98
    Re: New leaf net
    This looks the same as the one I got off ebay advertised as a Red Baron knockoff. I'm really happy with it.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,154
    Re: New leaf net
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    I bought this one. It might be the same frame but with a different bag. In fact, if you look at the second picture, it seems to show the one you referenced (though the brand is listed differently). The difference is the porosity of the bag. The Silt model does "catch" the water making it provide more resistance than the leaf model would. I've used mine for four seasons and it's in good shape.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jan 2016
    Sonora, California
    147
    Re: New leaf net
    Here is the little destroyer, haha.
    Jul 2012
    Tallahassee, FL
    34,023
    Re: New leaf net
    BUT Dad! I am SO cute! hehe
    Kim
    mamasmith's Avatar
    Apr 2017
    Canton, GA
    94
    Re: New leaf net
    I have an almost identical destroyer at my house!!
    He looks innocent here but don't let that sweet face fool you. Naughty!
    UNDER CONSTRUCTION: 544 sq feet in ground shotcrete pool, 3.6' to 6' depth, stone coping. Includes: Spa elevated 18 with stacked stone, Concrete Deck
, 18 raised beam with stacked stone Waterfalls on raised beam wall, Stacked stone on firepit side, 4' Firepit, Flagstone steps to firepit area
    Jan 2012
    8,594
    Re: New leaf net
    Is that a lab?
    Maddie
    Jan 2016
    Sonora, California
    147
    Re: New leaf net
    Quote Originally Posted by YippeeSkippy View Post
    Is that a lab?
    Maddie
    He is a lab/pit mix. Definitely has all the traits of the lab though. Can't keep him out of the pool and wants to chew everything!
