Thread: Do I NEED a professional?
    Apr 2016
    Abilene, TX
    12
    We are close to choosing a pool heater but can't decide if we need a professional pool guy to install it. My hubby is pretty handy and we're into doing it ourselves if possible to make sure it's done right. Also, I have read that buying heaters online is risky but our in-town choices are pretty limited. Any opinions? Thanks!
    13K gallon, 12' x 27' IG, Gunite pool
    Equipment- Tagelus TA60 Sand filter, Purex-triton separation tank, Rainbow 320 auto chlorine feeder, Pentair varispeed pump, Polaris 280 pressure cleaner w/boost rite 1.1 HP pump
    Zodiac Sheer Descent waterfall feature
    Solar Cover
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Do I NEED a professional?
    Are you replacing a heater or installing a brand new one for the first time? What kind of heater is it?
    Apr 2016
    Abilene, TX
    12
    Installing a new one. We have settled on a heat pump (too expensive to run the gas line for a gas heater) but haven't chosen a specific model yet.
    Solar Cover
    DFW, TX
    24,974
    You'll probably do fine with a smaller heat pump around 50k btu. It should add about 1 degree every 2 hours. The benefit ipoh a smaller heat pump is a smaller electric circuit, mine uses a 20 amp breaker. Bigger heat pumps use 50a or 60a service. I installed a Hayward HP50HA heat pump last fall. You'll need to install an electric circuit and do some plumbing. There are some pics of my install in my pool thread, link in sig.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Figure out which one you want and go hunt for the manual online and read up on installation. Then decide.
    I suspect reconfiguring the plumbing will be the hardest part, unless your equipment pad is exceptionally spacious. You probably have a panel out by the pool, so if there are vacant spaces for more circuit breakers and you aren't overloading it, the wiring should be pretty simple.
    Apr 2013
    Sacramento, CA
    2,769
    As Danny points out the issue with a heat pump is whether you feel you have the knowledge and comfort level taking the front off your panel, installing a new breaker and running a circuit to the new heater. Depending on the location of the panel and the heater a suitable electric line may not be cheap. It has to be in conduit and may have to be buried although with a few beers I can get creative. The electrical side is usually more intimidating than the plumbing side.
