Thread: Liquid chlorine dispenser
    Aug 2014
    Lincoln, NE
    20
    Has anyone had experience with the HASA pool liquidator? Thinking of adding one to help level off FC.
    12000 gallons IG vinyl June 1, 2005 Lincoln, NE
    Pentair high rate Tagelus sand filter Pentair 1hp single speed pump (WFE-4/011513)
    Pentair MiniMax NT Heater & Pentair Legend Pressure Side Cleaner
    Cover-Pools Automatic Pool Cover
    Taylor K-2006 Test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,323
    Re: Liquid chlorine dispenser
    I've used one for several years and like it very much.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Use the search box and you'll find many threads.
    I'm on my second year and am happy with it. A little pricey but does a good job.
    13,000 gallon in-ground, Pentair Superflo VS, C-1750 cartridge filter, Liquidator, sparkling clean water!
