Results 1 to 9 of 9
Thread: Owner/Builder in Louisiana
    Apr 2017
    Denham Springs, LA
    7
    Hey everyone. I'm new to the board. Starting on my first pool in a few weeks. Decided to go the owner/builder route.
    48' x 20' gunite with attached spa and a tanning deck. Will have a stone wall along the back with a couple of water features.
    Plan on using Hayward Automation system and equipment.
    Here is my design. Definitely open to suggestions and feedback. Thanks!! Can't wait to get started.
    May 2016
    Baton Rouge, LA
    59
    Re: Owner/Builder in Louisiana
    I too am from DS! Hope you did not have too much damage in August.
    Have not built a pool, bought the house with the pool already there. One thing that I would consider is the placement of pumps/filter. I would try to get the pumps as far away from the pool or sitting area so that you do not have to hear them. If the covered pavilion will have a back wall, then you may not have any issues. if the pavilion will have open sides, you may consider changing the location of the pump to another spot...Just a thought.
    I am sure everyone else will chime in with better insight and more specifics.
    25,000 gallon
    rectangle shape
    300 lb Sand filter
    Pentair Superflo Pump Variable Speed Pump
    Apr 2017
    Denham Springs, LA
    7
    Good advice. I am going to close in part of the pavilion and I'll definitely have a back wall on it.
    Are you still in DS, or in BR?
    May 2016
    Baton Rouge, LA
    59
    If that is the case, you probably do not need to worry about relocating the pump since there would be a wall in between. It should reduce the sound enough to where you can enjoy your pavilion while it runs.
    I moved to DS a couple of years ago. However, I left my location at BR as I figured more people would know where that is.
    Good luck with the build - I will be following along. Can't wait to see it all come together.
    25,000 gallon
    rectangle shape
    300 lb Sand filter
    Apr 2017
    Denham Springs, LA
    7
    Started forming up the pool today!
    Jan 2017
    St Augustine, FL
    593
    Wow! Huge pool! I looks like a great design. I see you wrote travertine coping. Are you using it for the deck too? Have you gotten to tile and plaster finishes and colors yet?
    37.5x17' 19.5k gal Shotcrete 3.5-7' w/sunshelf, 18" 7' spa with stone, Stonescapes Tropics Blue w/iridescent mini glass beads and abalone, Hayward Ecostar VS pump, Swimclear cartridge 200 sq ft, 40k SWG, Pro Logic automation, 3 Colorlogic lights (2 in pool, 1 in spa), 2 LED bubblers, 4' LED sheer decent on raised wall, Hayward 400k BTU heater, 1500 sq ft Silver Travertine French pattern deck, Lightstream tile, 34x56 Mansard screen cage
    Apr 2017
    Denham Springs, LA
    7
    Thanks! I have 6 kids and a bunch of nieces and nephews so I had to go big!
    I'm actually going with a stone coping and stone tanning deck because I have access to a bunch of free natural stone. For tile, I'm using slate. For plaster, going with pebble in a variation of cool blue for the color.
    Here is the equipment I'm using:
    - Hayward Super Pump, VSP, 1.5 Max. HP, (SP2603VSP)
    - Hayward TriStar Waterfall Pump
    - Filter - Hayward DE3620
    - Heater - Hayward 150,000 BTU | Natural Gas | H150FDN
    - Hayward GVA-24 Valve actuators
    - Automation - HaywardGoldlinePL-PLUS-16VProLogic with T-15 Cell
    - Lights - HAYWARD COLORLOGIC 160 1.5" LED LIGHTs
    - 2 HaywardColorLogicBubblers
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    There is a lot of support from folks (and installers) here for Raypak natural gas heaters instead of Pentair or Hayward. On that item in particular (which happens to be one that it is not necessary to have the same brand equipment as your automation) the Raypak design is simpler and less problematic from their experience.
    Check into the light controller necessary to perform the more complex/custom light shows. It does not come standard with the automation you have as I understand it (though I could be wrong). Without it you can see different colors but must use the power button to sequence between them - and you can't do the complex or custom shows. I know because I can't do the fancy stuff.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2017
    Denham Springs, LA
    7
    I'll check out the Raypak heaters.
    And I'm also looking into the light controllers for networked lighting. Might be something that I upgrade to after a little time with the pool.
    Appreciate the feedback!
