Thread: Foam insulation board
    Jun 2016
    Farmingdale, nj
    40
    Unhappy Foam insulation board
    Hey everyone..so we are putting our Intex pool back up this season the proper way, level and with no creases, and I would like to do foam board underneath. I searched forms up and down for the last week and can't decide between half inch or 1 inch board. I did some research and realize the pink board in both sizes has the same compression rating of 15 psi. It's only when you get up to the 2 inch board that the compression rating increases the 25 psi. The pool were putting up is an 22 by 52 Intex ultra frame and i just want to make sure the half inch board will be okay before purchasing. I went on Home Depot's site and can't find 3/4 inch board.
    Any input would be helpful.
    Intex 22x52 AG, 12,000ish, Krystal Clear Cartridge Filter 2,500gph, K-2005 test w/ FAS-DPD soon to be on order, Chlorine
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    686
    Re: Foam insulation board
    Basically the denser the foam the more it will withstand compaction. The white kind that has the silver foil on one or both sides is a very loosely packed foam panel and can be easily compressed down to next to nothing in thickness. The pink and blue foam sheets are heavier or what they call an extruded foam. The process of making it creates a much denser foam which isn't as prone to compressing and forming divots from feet and knees as you walk and kneel on it to install it. I would suggest staying away from the non extruded foam panels such as the ones that look to be composed of white foam pellets and opt for the more rigid blue or pink panels.
    Thickness really is just a personal choice. 1/2, 3/4, or even 1 inch is fine. I went with the 3/4 inch tongue and groove blue foam panels because that was what was available at our local lowes in the extruded form. Then held them all together with about 4 layers of gorilla tape over each and every seam.
    In the very least I'd say nothing less than 1/2 inch otherwise you might as well just be putting down a gorilla pad or some other form of liner protection padding.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I went a little cheaper and used the white unfaced foam. BUT I started with 1.5 inch thickness to match my pavers. It has compressed about 1/8 of an inch. It is not enough that you can detect the foam-paver junction. The only way you know when you are standing on a paver, is that the paver has no "give" to it.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jul 2014
    Oakbank, Canada
    429
    Home Depot sells a 1" foam that is used for insulating under cement. That is what I used. Have foil on one side, and film sheet on other. Not sure of they sell it in the USA though. 3 years use so far and its great.
    Durofoam EPS Rigid Insulation 96Inch X 48Inch X 1Inch | The Home Depot Canada
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
