Results 1 to 7 of 7
Thread: Intermatic T103 timer help
    Oct 2016
    Huntsville, AL
    18
    Not sure if this is the right forum for this question, but here goes.
    I wired in my T103 timer earlier this week. The pump will turn on and off with the manual override switch, but the timer dial is not moving.
    Here is how I have it wired (this is a 220V circuit). (Note, I followed a wiring diagram I found online that more clearly shows the layout than the sticker inside the timer door)
    From the breaker to the timer:
    White wire to 1
    Black wire to 3
    Green wire to the green grounding screw
    From the pump to the timer:
    White wire to 2
    Black wire to 4
    Second white wire (ground wire) to the green grounding screw
    There is nothing attached to the "A" lug, which appears to be a neutral. These are exactly as the instructions called for, however the only way it works is in the manual position. What am I doing wrong? It seems as if "A" should have a wire attached, but not clear on which wire that should be.
    20x40 rectangle in ground vinyl pool - 48k gallons
    Curved slide
    Hayward 1hp single speed Superpump, Pro Series S244T sand filter, 1.5" VariFlo XL multiport valve
    Aquabot Turbo-T automatic cleaner
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    Re: Intermatic T103 timer help
    N,
    It appears to me that the clock motor only runs off of 120 volts. So you need the neutral attached to have the clock motor work.
    Oct 2016
    Huntsville, AL
    18
    Thanks Jim,
    So in that event, I would need to remove the green wire from the ground lug and attach it to the "A" lug? I am assuming the ground wire from the pump itself can remain on the ground lug.
    Curved slide
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Quote Originally Posted by Nlambert View Post
    Thanks Jim,
    No. Green is ground and ground alone.
    Jul 2014
    Bedford, TX
    9,277
    N,
    I assume by your answer, that you have no neutral. If that is true, then "technically" that timer won't work for you...
    Oct 2016
    Huntsville, AL
    18
    Jim, that is correct. I have a 3 wire setup. White, black, and green from the breaker to the box and black, white, and white on the pump. The wire is 10/3 wire. That stinks because the timer says it works with 120V/240V applications but doesn't mention that the 240v side only works with a 4 wire configuration. What other options are available?
    The instructions I followed were for a T104 model from the link below:
    http://www.inyopools.com/HowToPage/h...?CommentPage=1
    It doesn't mention hooking up a neutral either and seems to have a similar configuration to mine. Is the difference between the T103 and T104 timer the neutral hookup?
    Curved slide
    Richard320's Avatar
    Jan 2010
    20,303
    It appears the T104 uses a 240V intermal motor, so it just hooks to the two hot wires.
    http://waterheatertimer.org/pdf/Inte...-t104-240V.pdf
    You could probably switch the motors.
