Thread: Any maintenance needed for scuppers?
    May 2015
    VA
    10
    I have 3 copper bowl scuppers. There is some water that sits in the bottom of them, and obviously the pipes, when not in use. Should I be treating them with anything on a weekly basis since that water is not circulating on a constant basis with the rest of the pool or is running them at least once a week enough?
    20x40, IG, gunite, rectangular, 32k gallons, 3'6 - 8'6 deep, filled 8/5/2016, 36" raised beam, 3x hammered copper wall bowl scuppers w/ pump. 8' diving board. FNS Plus 60 DE filter, IntelliFlow 2 VST pump, IntelliChlor IC40 SWCG, Rheem 400k btu propane heater, Blue Surf PebbleSheen, Easytouch control system w/ ScreenLogic Interface, 2x IntelliBright 5G LED lights, Polaris 380 cleaner w/ booster pump.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,883
    Re: Any maintenance needed for scuppers?
    Most members that have scuppers or waterfalls or anything like that make sure to run them for about 15 or so mins each day for this very reason. Best to have "new" water in them daily during the summer months.
    Kim
    May 2015
    VA
    10
    Thanks!
