Thread: Pump Replacement
    May 2017
    Clovis, CA
    1
    Pump Replacement
    After 11 years it's finally time to replace my pool pump. I've had no problems (until now) with my PENTAIR and would like to stay with the same unit, P6RA6YF-206LM. I noticed that PENTAIR has a model P6RA6YF-206L (no M) that sells for $150.00 to $200.00 less. The specs appear to be the same, does anyone know what the difference is between these models?
    I'm in California if that makes a difference
    Thanks in advance....
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pump Replacement
    Best I can find is that the "LM" pump you have is simply an older pump and the "L" pump is the current production. Other wise the two pumps look identical in performance so far as I can see.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
