Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: First time opening - CYA and CC question
    May 2017
    Indianapolis, IN
    17
    Last summer was my first time owning a pool. That time I had someone professionally open and close it, mostly because that same person installed a brand new vinyl liner. This year I decided to open and close myself.
    When I took off my cover Sunday (three days ago) the water was practically black. Just before I'd had the water tested and these were the results:
    FC: 0
    TC: 0
    CH: 140
    CYA: 0
    TA: 110
    pH: 7.8
    Since then, I've added 16oz of algeacide (split between two different 8oz doses on different days) and also 4 lbs of cal hypo powder (split between 2 2lb doses on different days.) As of yesterday the water was a nice turquoise color instead of black, though still very cloudy. I have about 2.5 ft visibility in it. I had been running the pump 24 hours that entire time (had to backwash once) until last night. So the pump ran 24hrs for almost three days. I've also brushed down the sides and bottom three times in the last three days.
    I made the assumption that the cloudiness was more algae, so last night I decided to try that HTC Green to Clear product. This called for me to turn the pump off. It worked in raising the dead algae to the top and then sinking in, but of course now I can't see the algae because it's all dead at the bottom and water is still cloudy.
    That's when I started doing more research and found out about Combined Chlorine, and I'm guessing that's what my cloudiness is coming from. At this point, here are my readings that have changed:
    FC: 1-2
    TC: 5
    CC: 4-3
    (I can't get the exact FC and CC count because I really have a hard time telling from my DPD test kit the color difference in the first two levels)
    From researching the forum here, I can see that I probably should have used bleach instead of cal hypo to start up the pool. I still haven't added any CYA because my pool store instructions say to remove algae first.
    Here's my plan moving forward: I plan to vacuum out the dead algae as best I can, turn the pump back on to filter, and begin adding bleach on the SLAM procedure.
    Questions
    1: Should I actually begin adding CYA now instead of waiting?
    2. Through several comments from JasonLions on this forum, I was finally directed to this thread:
    Please Explain Breakpoint and of Sodium Hypoclorate
    This seems to debunk the 10x rule for CC. Using my numbers, what should be my target shock level? I'm still a bit confused on that. And I really want to get this right because I just installed my liner last season and am mortified at the idea of burning it up.
    3. Is the rest of my plan sound? Should I try to vacuum the algae off the bottom first or just wait til the water clears up first?
    Any help is very much appreciated.
    John
    15,600 in-ground pool, chlorine, vinyl liner, sand filter, city water, FAS-DPD test
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: First time opening - CYA and CC question
    Welcome to the forum. Before anything else...........you're gonna need one of the two "drop based' test kits we recommend in Pool School. Then................this:Pool School - SLAM - Shock Level And Maintain
    There's your SLAM level chart.Pool School - Chlorine / CYA Chart
    May 2017
    Indianapolis, IN
    17
    Thank you for your reply. I have a DPD test kit that tests free chlorine, total chlorine, pH, and alkalinity. Is that one of the two suggested?
    I found the CYA chart yesterday. The reason I posted my question is because there are no entries on it for 0 CYA. Am I to assume that means I should begin adding CYA despite algae most likely being present in my pool? It's not completely clear yet, there's a small tint of green to it. So I'm assuming there's still some algae in it.
    John
    Apr 2010
    East Texas
    10,158
    What you are looking for is a fasdpd FC test kit which is comprised of a powder and a liquid that can ACCURATELY measure to 50 ppm FC in .5 increments. TF100 or Taylor K-2006C. Use FC of 10 for CYA level of zero.
    May 2017
    Indianapolis, IN
    17
    New question: how long do people typically wait to test the water after they've shocked the pool? I'm seeing a lot of different answers on the forum.
    According to the calculator here, I was required to dump 324 oz of 6% bleach into my pool to attain 10ppm FC. The bleach I bought from Aldi last night said 8% and I put in 384 oz. I did a quick brushing of the sides and swished the water around with my pool brush to hopefully mix it up a bit quicker. I did a reading right after that and it looked like my free chlorine was only a 3 instead of a 10. Then I did a reading about an hour later and it looked about the same. Did another one this morning as part of an overnight test (turned off the chlorinator) and it looked like it sank to maybe a 2.
    At any rate free chlorine is nowhere near the 10ppm required. Any ideas why that might be? Maybe the bleach is junk or possibly the test? It has been raining a lot at my house, but I don't know if that's enough to mess with it that much. It looks like my TC is up around 10ppm.
    John
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    You are not going to be able to do this without an FAS-DPD test. So you might as well just add a gallon of bleach a day with the pump running until you get one. Well, that and get as much debris off the bottom as possible.
    To answer your question though, bleach is going to be quickly consumed, especially in a black pool. You will need to test and add frequently.
    I suggest adding a gallon of bleach a day and keep refreshing the tracking page on your FAS-DPD test
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2017
    Indianapolis, IN
    17
    Yeah, I've got one ordered. Pool's actually no longer black. It's blue but just really cloudy and still can't see the bottom.
    Just to make sure I'm understanding you right: when you say the bleach gets consumed quickly - do you mean like within five minutes? Because that was the amount of time that elapsed between when I dumped it in and tested.
    John
    30,950
    You should read the SLAM article and follow that to clear your pool. What you are doing now is sortas' stopgap and may or may not get you swimming.
    May 2017
    Indianapolis, IN
    17
    Thanks. I have read the slam article numerous times and understand that I need to wait for my better test to arrive (again, it's been ordered) before I can do it accurately. I'm still wondering if it's possible for a pool to drop 7ppm FC within five minutes.
    John
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Yes. It's possible you have ammonia. That is why you should wait on your test kit before adding CYA or anything else besides bleach.
    May 2017
    Indianapolis, IN
    17
    Yep, I'll wait. Thanks again to everyone for the help.
    John
    May 2017
    Indianapolis, IN
    17
    I got my FAS-DPD test Saturday and started following the SLAM process. I've been adding bleach to bring up to shock level as often as possible for me. Saturday I shocked six times starting around 1pm and yesterday I shocked four times starting 7:30 am. I brushed down the sides of the pool once on both days and the pump/filter have ran continuously.
    The combined chlorine was falling nicely, drastically at first and then slower. But now it's started to come back up. It was 7ppm when I started SLAM on Saturday. It hit it's low yesterday at my 4:30pm reading where it was .4ppm.
    After that I added water from my hose because I wanted to do more sweeping of dead algae and debris on the bottom today. After the water addition, my next test was yesterday at 9pm and the combined chlorine went back up to .6ppm. When I tested the water this morning at 6am it was up to 1.2ppm.
    Has this happened to anyone else before while they were SLAMing? Is it possible that adding water created more combined chlorine in the pool, or does this just happen sometimes? I never had a combined chlorine problem all last summer so this is something new for me.
    John
    May 2016
    MD
    195
    I think it means you are killing things...
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    triptyx's Avatar
    Apr 2016
    1,476
    You don't have to use the 25ml water sample for the FAS/DPD test - this is actually a waste of reagent for most uses.
    Use a 10ml water sample, and divide the number of drops by two to get your result. This will save you a lot of reagents - critical when you're slamming.
    CCs are a result of the chlorine working. They are removed from the pool by sunlight breaking them down. Don't stress too much about them going up or down, just keep SLAMing until the SLAM end requirements are met.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2017
    Indianapolis, IN
    17
    Quote Originally Posted by triptyx View Post
    Cool, that helped put my mind at ease. I was starting to worry I was doing something wrong when they started going back up again. Thanks for the informative answer.
    John
    Smartjack's Avatar
    May 2016
    Naperville, Il
    124
    When SLAMing (and only when SLAMing), I use a 5ml sample. I got a $3 medicine dropper at Walgreens that lets me get a very accurate 5ml level of water. That gives me 1 drop per 1 ppm FC level. That is plenty accurate when checking high chlorine levels during a SLAM, and saves a ton of reagents. Once the SLAM is over, I go back to the 25 ml testing.
    Bruce - (The SmartJack was an invention of mine, and became my nickname)
    Fox Pool 40x27 IG Vinyl, Lagoon Shape, 27,000 gallons, Hayward 300,000 BTU heater
    Hayward 1.5 HP, 2-Speed SuperPump, with Hayward C4025 Cartridge Filter
    Polaris C-310 ORP Controller, modified to pump Liquid Chlorine
    Hayward Phantom, and Aquabot Turbo T-Jet automatic pool cleaners, Taylor K-2006
    May 2017
    Indianapolis, IN
    17
    SLAM complete! Passed the SLAM conditions yesterday morning and began routine maintenance last night. Just wanted to thank everyone on the forum who helped out with suggestions here. You definitely saved me a lot of time, money, and guess work.
    Pool went from this:
    To this:
    It only took a small amount of bleach. *sarcasm
    John
    Jun 2014
    17,333
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    5 days from black to clear. That's pretty impressive.
  20. Back To Top    #20
    May 2017
    Indianapolis, IN
    17
    Quote Originally Posted by Mr Bruce View Post
    Oops, should have probably been more specific. It was actually about ten days. The first five days was before I came on here and started asking questions, though. There was sporadic, random back and forth progress during that time. Once I actually figured out what I was doing and got help from you guys (the latter five days), progress was way more steady and constant.
    Also, Texas Splash, love the Bill Murray badge! Bill Murray is amazing.
    John
