Results 1 to 7 of 7
Thread: How to repair a large vinyl tear in corner?
    Jun 2012
    Louisville, KY
    266
    I have a 10" horizontal tear in the corner gaping maybe 1.5". The liner is old and this is the first sign of failure otherwise the integrity is good. Can I just use a patch of liner material and some cement that comes with a patch kit? My only concern is the thickness of the vinyl is very thin there from sun and the cement could possibly make it worse. The location is above water in a corner but there is plenty of material between the tear and the bead/coping, maybe 3".
    I guess I could make the patch extra big? Thanks in advance. Just trying to get one last season out of it before replacing.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Jordy Verrill's Avatar
    May 2016
    Cincinnati, Oh
    41
    Re: How to repair a large vinyl tear in corner?
    If you are just trying to squeeze one more year out of the liner, you might want to look into a product called Flex Tape. I don't know if anyone here would recommend it, but it is a completely water proof rubber tape that can be used to patch holes on pretty much any surface. It might not look beautiful, but it is a quick, not too expensive quick fix.
    16x32, In Ground, ~20,000 gallons, Vinyl
    1hp Hayward Pump, Hayward s200 Sand Filter, Raypack Heater (rarely used)
    Taylor K-2006 test kit
    22,703
    Just make a large patch and cover a lot more area than the existing tear. You may be able to get a pretty good sized piece of liner from a local pool store or builder that may somewhat match if you ask them. They usually have scrape pieces laying around.
    I've never used Flex Tape, but if it'll stick to the vinyl liner well enough, that may provide a temporary fix.
    Jun 2012
    Louisville, KY
    266
    Thanks all, I can easily get big pieces of liner and don't care how it looks so I'll just patch with cement.
    Apr 2017
    Greensboro, NC
    189
    87 of these.
    20k gallon, in-ground, vinyl liner, well water
    Hayward S200 sand filter, Hayward SP2607 1HP pump, Hayward HP21002 heat-pump
    Jun 2012
    Louisville, KY
    266
    Quote Originally Posted by sccm_sysadmin View Post
    87 of these.
    The thought did cross my mind. And 87 seems...familiar.
    Apr 2017
    Greensboro, NC
    189
    Quote Originally Posted by spidey07 View Post
