Thread: Questioning My Start Up Tech
    Jun 2015
    Las Vegas,NV
    16
    So I am 3 weeks into having water in the pool. waiting another for the salt system to be installed. When I last talked to my PB start up tech, he claimed that Pentair SWG liked a higher level of salt than others, around 4000ppm. Has anyone else heard or experienced this. My other concern is, I have the Master temp 400 with the copper heat exchanger. If I recall, 4000 was out of the range limits for this heater. Please let me know your thoughts.
    Thanks
    Drew
    12K Gallon Quartz IG Pool & Spa, Waterfall with 1.5 HP Whisperflo , Easytouch 4, SWG IC40, 3HP IntelliFlo VS, Screenlogic 2, MasterTemp 400K, TF-100
    Apr 2017
    sacramento CA
    147
    Hi I have a full pentair system and have the same equipment as you. Ic40 and mt400. Just to let you know it's a great heater. It heats up my 7 ft spa in under 30 minutes. The sweet spot for pentair swg is 3600 ppm. If you have the ScreenLogic program on the pc or the app on your phone it will show you the level. I'd suggest you purchase a salinity test kit from Taylor. It's part number K-1766. Then you can double check and compare the results from your swg.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Re: Questioning My Start Up Tech
    Most pool "professionals" learn their trade at the side of an older pool professional. Seldom do they go to formal training classes or even read the manuals of the products they install. So, if they learn bad information they continue to pass it along.....
    Support the site
    Apr 2017
    sacramento CA
    147
    They are a lot worse than that Tim. I remodeled my pool this year and I wanted to get a break from maintenance for a couple of months so I hired a pool guy. What a waste of my money. The guy flipped the switch on my valve and didn't set it back to the correct setting. I was in Hawaii when my daughter wanted to use he spa. She turned it on and the spa started to drain. I had to FaceTime her for over an hour from Hawaii trying to figure out what he did. I fired him when I got back.
    Mar 2017
    House Springs
    97
    I am all pentair and hold salt right around 3200
    Pool: 14,000-gal IG
    Filter: Pentair Sand Dollar, Pump: Pentair Superflo VS
    Automation: Pentair EasyTouch w/ Autelis, Lighting:Globrite
    Pentair SWG IC20, Prowler 820, K-2006
