Results 1 to 8 of 8
Thread: Alkalinity
    Dec 2015
    Arnold md.
    113
    Alkalinity
    Hello all,
    I know my alkalinity is a little low, 50, but my ph is stable and Fc looks good too. My question is, if I raise my Alkalinity a bit will it help with some plaster discoloring?
    Recent numbers
    Fc- 4
    Cc- 0
    Ta- 50
    Ph- 7.4
    Cya - 70
    Thanks
    Vinny B
    IG Plaster 20x40
    Jandy 1.5hp cartridge filter
    Chlorine pool mineral set up/no longer using
    test kit k2006
    30,941
    Re: Alkalinity
    I would not touch a thing pH stability is what you are saeeking and you have it.
    Pool staining is (essentially) unrelated.
    Can you post a decent pic of the stains?
    Dec 2015
    Arnold md.
    113
    Re: Alkalinity
    Thanks, yeah will post when I get home. The stains have gotten less since I opened but still seem a bit much since the pool is only 2.5 years old. They are mainly on the sides of the pool.
    Vinny B
    IG Plaster 20x40
    test kit k2006
    Dec 2015
    Arnold md.
    113
    Re: Alkalinity
    Here is a pic from the top looking down the sides Image1493846106.349512.jpg
    Vinny B
    IG Plaster 20x40
    test kit k2006
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Re: Alkalinity
    You have a "mineral set up" you say? As in copper and silver and all that kind of thing? Those can certainly cause stains.
    I'd suggest you take a pool water sample to a pool store and ask them to test for metals to see how high you may be? Its is the ONLY time we suggest pool store tests, because the kit is kinda pricey to buy.
    Give us a full set of numbers:
    FC
    CC
    pH
    TA
    CH
    CYA
    Thanks
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Dec 2015
    Arnold md.
    113
    Re: Alkalinity
    Quote Originally Posted by YippeeSkippy View Post
    FC
    CC
    pH
    TA
    CH
    CYA
    Thanks
    Maddie
    Yes it is a mineral pool, but I don't have to use the minerals and I have not put one back in for this year. My other numbers are good,
    I will ck the pool store results tomorrow. Thx
    Vinny B
    IG Plaster 20x40
    test kit k2006
    Dec 2015
    Arnold md.
    113
    Re: Alkalinity
    Quote Originally Posted by vbertone View Post
    Ok 0 on metals so i did the vitamin c test and no change in the stain either. I will say it has gotten less over time but still worries me a bit.
    Vinny B
    IG Plaster 20x40
    test kit k2006
    Dec 2015
    Arnold md.
    113
    Re: Alkalinity
    ok so wanted to check back on this. I have found out that the stains are in fact metal of sorts, no metals showed up in my water most likely because there is none in the water but stuck on the plaster. I have seen prior threads that discuss uses of Jacks Magic #2 and that is also what the Pool guy recommended. I just get nervous with what that will do to my pool chemistry. Any thoughts?? My numbers are great otherwise...
    Vinny B
    IG Plaster 20x40
    test kit k2006
