Thread: Pentair VS pump cover stuck
    Oct 2007
    Parkland, FL
    753
    My pentair VS pump cover is stuck. Anyone had this happen and how did you remove it? Before I hit it with a hammer was wondering what other people have tried? I've removed it a few times before but this last time it just won't budge.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Re: Pentair VS pump cover stuck
    Hi. Do you mean the filter cover? You should first remove pressure if possible so the water drains. I use a soft rubber mallet to open mine.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Oct 2007
    Parkland, FL
    753
    Yes the basket cover.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,259
    Rob,
    I often use a rubber mallet to open the pump-basket lid on my IntelliFlo..
