Thread: At what point is it safe to be in the water?
    Aug 2016
    Warminster, PA
    37
    New pool owner here--thanks to all for the advice so far. At what point after opening in the spring is it safe to be in your water? Assuming the water is clear, do you wait to see any specific testing parameters over a period of time before using the pool? Or is it safe to be in once pH and FC are within normal range?
    Viking Coronado IG Fiberglass 13k gallons, Pentair Intelliflo VS Pump, Pentair Cartridge Filter (320 sqft), Pentair Electric Heat Pump (125k btu), Pentair Intellichlor IC20 SWG. TF-100 Test Kit. Located in SouthEastern PA.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: At what point is it safe to be in the water?
    If you can see the bottom, and pH and FC are in range, you probably won't die from getting in. People swim in lakes without ever testing them, right?
    Personally, I like to wait until the water is warm, too.
    Apr 2013
    Sacramento, CA
    2,769
    When ph and FC are within normal range its safe. If you are getting more than.5 to 1 of combined chlorimines in your test results you should SLAM and wait until the OCLT has .5 or less.
    Aug 2016
    Warminster, PA
    37
    LOL. Great point. Somehow swimming in the lake or ocean never crossed my mind. I prefer it warmer too, but I don't think my labrador will mind the temps much!!!
