Thread: Chem feedback please.
    May 2015
    VA
    10
    Opened pool and chemistry is getting close I think. Looking for feedback on next steps especially for CH.
    FC = 6.5
    CC = 0.5
    TC = 7.0
    CH = 150
    TA = 50
    CYA = 60
    PH = 7.0
    If I used the pool math calculator correctly I think I should be adding the following:
    - 44oz of stabilizer to bring up CYA from 60 to 70
    - Lower IntelliChlor generator % a hair to bring FC down slightly (currently at 40%)
    - Add 150oz of baking soda to raise TA from 50 to 70
    - CH - pool math says add about 89lbs of calcium chloride to go from 150 to 450
    - For PH I was thinking since its close and tends to rise a bit on its own I would just let it be
    Should I be doing all the above at once or step by step and re-assess?
    Thanks in advance
    20x40, IG, gunite, rectangular, 32k gallons, 3'6 - 8'6 deep, filled 8/5/2016, 36" raised beam, 3x hammered copper wall bowl scuppers w/ pump. 8' diving board. FNS Plus 60 DE filter, IntelliFlow 2 VST pump, IntelliChlor IC40 SWCG, Rheem 400k btu propane heater, Blue Surf PebbleSheen, Easytouch control system w/ ScreenLogic Interface, 2x IntelliBright 5G LED lights, Polaris 380 cleaner w/ booster pump.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: Chem feedback please.
    Raising your TA might help inch up your PH a tad. Everything else looks good.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Rule of thumb here is to add things thirty minutes apart, except for CYA, because it takes a while to dissolve.
    I've never had to add any, but I have read here plenty of times that adding a bunch of Calcium can cause temporary cloudiness. So don't panic if it happens to you. Just leave the pump run and be patient.
