Results 1 to 8 of 8
Thread: Going with Coleman
    May 2017
    Waterloo,SC
    5
    Going with Coleman
    Hello. I'm new here 😀...we recently set up a 2654 Coleman with an intex sand filter and salt water system. I added 10 bags of salt and have been running the pump and system for about 10 days. I checked the levels today and I believe everything was good except the chlorine level was very low. What should I do to get the chlorine level right? Any advice will be greatly appreciated.
    ~Clueless new pool owner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Going with Coleman
    Welcome!
    Did you add stabilizer aka Cyanuric acid, or just salt? Without some CYA in there, your SWG is going to be working overtime and unable to keep up with the demand just from solar degradation.
    And if what I typed is gibberish, here's the secret decoder: Pool School - ABCs of Pool Water Chemistry
    Jun 2015
    Stockholm, Sweden
    261
    What do you mean by "chlorine level very low"? With an SWG you will have lower FC levels than in a regular pool, that is one of the benefits. The disinfection takes place inside the cell, where the level is much higher than in the pool. The Intex manual states that FC level in the pool should be 1-3 ppm and never go above 3. They also recommend CYA at 30-50. If the water looks and feels good, you are alright.
    How long do you run the SWG each day? You need 10-12 hours with your size pool. Run the Boost program if you need additional chlorine, e.g. if the weather is exceptionally warm, lots of people in the pool etc.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jan 2012
    'burbs of Augusta, Georgia
    8,587
    When ever you need a dose of FC fast, use plain unscented non-fancy bleach to raise that chlorine level. *Then* you can let your SWG maintain it, but its hard for a SWG to get your chlorine up to the desired level because they work very slowly.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    May 2017
    Waterloo,SC
    5
    All I added were the 10 bags of salt...I tested with a 6-way strip thing and it says everything is low. I'm using an app for the clorox brand pool chemicals...it tells me I need several different chemicals to add to my pool. I'm hoping to avoid this! I seriously have no idea what I'm doing! This pool and all the maintenance is very intimidating but I'm determined to get the hang of it!!
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by Turtlemama View Post
    I see a couple problems. First is test strips. Even if they work perfectly when brand new, moisture messes them up. They also have vague ranges... 50-100 isn't very accurate. And instinct is to set the wet strip on the color sample card. Except that then causes the test water to wick around and bleed into the neighbor. So... lack of a proper test kit is the first problem.
    Second, no CYA. It acts as a sunscreen so sunlight doesn't destroy all the chlorine the saltwater generator just made. It's a one-time thing. Add it and it stays there. You don't lose the convenience of the SWG by daily additions of it.
    Start here: Pool School - Test Kits Compared
    Once you've chosen a test kit and ordered it, get some CYA in that water. If your pool is 26' round and is filled to 4 feet deep. it's about 16000 gallons. You need 10 lbs of Cyanuric Acid aka Stabilizer to get to 75. You can buy it in the pool section of a big box hardware store or pay a premium and get it at the pool store. How to add it is described in Pool School - Recommended Pool Chemicals I'd get that taken care of quick, before the days get even longer and the sun gets more intense. And in the future, we'll expect you to calculate doses using your test kit and poolmath. We'll be happy to doublecheck, but we're not ones to tell you add this and this and this. Any pool store can do that.
    Start reading pool school articles until you're like this I'd suggest you confine yourself to Getting Started, ABCs and the Chemistry page, especially how to use poolmath.
    May 2017
    Waterloo,SC
    5
    Thank you so much!!! I'm ordering the test kit now!
    Jan 2012
    8,587
    Don't put ANYthing in the pool labeled "Clorox XtraBlue"..... they contain copper which you do NOT want in your water.
    Thankyouverymuch.
    Maddie
