Thread: Opening Question
    Jun 2015
    Wamego/KS
    123
    Opening Question
    Opened up a little earlier this season hoping to not have black water. It's a little cloudy but still blue. Water temp is still at 59. I read that algae shouldn't grow under 60. Am I better off just cleaning out the leaves and stirring up the dirt a few times a day for the filter to clean up the water and waiting until water temp is over 60 before starting to add bleach? Am I wasting bleach adding when the water is so cold?
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Opening Question
    Certainly remove any debris.
    No algae below 60 is not an absolute rule. The surface of the pool may get that warm, anyway.
    If it was me, I start vacuuming and by the time I was done, the water for sure would be mixed and I could test it and adjust pH and FC right then. If you don't have algae, and the water is cold, you lose hardly any FC. Even here in sunny SoCal, in January and February I might only lose 2 or 3 FC in a week!
    Jun 2015
    Wamego/KS
    123
    Thanks!
