Results 1 to 9 of 9
Thread: Time To Open - Advice Please
    Dec 2009
    Virginia Beach, VA
    135
    Cool Time To Open - Advice Please
    Pulled the cover back and the water is nice and .....black/dark green. But I'm used to that. Here are my chemical levels. Please let me know what the order of events I should do.
    FC - 0
    CC - 0
    pH - 7.0
    TA - 10
    CH - 30
    CYA - 0
    Salt - 330
    As you can see, everything is quite low which is surprising because everything was good when I closed in September. I did lower the water level below the returns but I do that every year. The CYA is what really has me scratching my head. I tested that one twice (remixed and everything). My chemicals are from last year so they MIGHT be old but I've never had issues with that before. I may try to take a trip to the pool store to get them to second check.
    Provided the numbers above are correct, what should I do first....next....so on with the chemistry.
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,302
    Re: Time To Open - Advice Please
    Was the pump on and has the water mixed before you pulled a sample? You could have a layer of fresh water from rain sitting on top that you tested.
    Dec 2009
    Virginia Beach, VA
    135
    That would be a negative. I have not run the pump at all. That makes perfect sense. I'll pull all the plugs from the fittings and start up the pump and let it run for a while. How long before it's mixed enough to pull a new sample?
    Completely different question. I just installed a new pump (Pentair SuperFlo 2-speed). Is there anything I need to do other than prime it a bit before I start it for the first time???
    Richard320's Avatar
    Jan 2010
    20,302
    Quote Originally Posted by jobondur View Post
    Half an hour should be plenty. Less if you brush or vacuum at the same time.
    No clue about the pump. Let someone who owns a two-speed answer that
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    As for the pump just make sure it is full of water before you start it. Don't let it hunt for prime for more than 30sec. If you fill it and it primes right up you're good to go.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Dec 2009
    Virginia Beach, VA
    135
    I let it run for a couple hours on low speed and here are the results:
    FC - 0
    CC - 0
    pH - 7.5
    TA - 30
    CH - 50
    CYA - 10
    Salt - 930
    So as you can see, the numbers are better but most are still somewhat on the low side. I looked back at my log and my CYA was roughly 50 when I closed in September. I drained about 1/3 of the water and I am now up over the top of the skimmer housing, so I've had a fair amount of rain. I'm going to order some new chemicals but I'm assuming the numbers are right for now.
    Sooo....I read somewhere on here that I should bring up the Cl level to like 10 and then see if it will stay there for roughly 10-15 minutes. Once it does that, I add enough CYA to get me to say 30-40 and then SLAM????? That sound right?
    And do I add DE before or after the CYA?
    Richard320's Avatar
    Jan 2010
    20,302
    FC - 0
    CC - 0
    pH - 7.5
    TA - 30
    CH - 50
    CYA - 10
    Salt - 930
    Yes, you have the chemical sequence correct. That quick check is just to see if your CYA broke down into Ammonia. Don't forget to use a sock for the CYA, because your filter will likely need a lot of backwashing and if you follow the bottle directions, you may end up literally flushing it down the drain.
    You should add DE before you run the pump for very long, because you don't want to run the filter without it. Particles can get stuck in the grid fabric without the layer of DE to coat them.
    Dec 2009
    Virginia Beach, VA
    135
    For the SLAM process I'll be brushing every day. But after the first time I vacuum to waste (pool level is super high) can I just use my robot to finish it up or am I better off doing it manually? I know the robot manual says not to use it when shocking the pool. Will I have issues using it when the FC is around 15?
    I HATE vacuuming.....
    Richard320's Avatar
    Jan 2010
    20,302
    Probably not. Assuming you stick to the FC/CYA guidelines we have, shock level isn't really all that aggressive. Guessing it's comparable to 3 FC in a pool with no CYA. The manufacturers are worried about the guy who nukes a pool with no CYA with a bucket full of "shock" powder.
