Thread: Plumbing water to add slide to existing pool
    May 2014
    philadelphia PA
    27
    When we installed our pool a few years ago, I never considered a slide. A lot of construction and concrete later, we are considering adding one. I have a corner behind a fireplace pavilion that would likely work best, problem is, how do we get water there? From what I'm reading, water from the pool return is typically used- I am not wanting a major disruption of existing concrete so I'm not sure if it's even possible to get water where it needs to come from and send it to where it needs to go.
    Any thoughts?
    Here are photos from when the pool was installed
    Here is the pool area now
    Pump is a good 25 feet in the direction of the arrow
    Leisure 34' Riviera fiberglass pool installed 2014 (~15000 gallons). 150 sq ft cartridge filter, SWG. Aquacomfort heat pump. Test kit- Taylor K-2005, Taylor FAS-DPD drop test kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Re: Plumbing water to add slide to existing pool
    Before you go too far down the road of getting the water there make sure the slide you are interested in can be installed in that location with the depth/slope of the pool wall/bottom. Failure to follow the slide manufacturer's requirements may result in a cancellation of your homeowners insurance.
    Support the site
    May 2014
    philadelphia PA
    27
    Thanks! Yes, researched footprints and required space and depth and have a few options if accessing water isn't too much of an issue.
    Mar 2008
    Los Angeles, Ca
    252
    I connect my slide to a garden hose via an adaptor that comes with the slide nozzle kit. Means you have to drag a hose over when you want to use the slide, but also didn't have to do any plumbing.
    Note the slide is old, and originally had a plumbed line, but that line broke so I use the hose. The line was from house water, not pool water.
    25,000 gal fiberglass pool, Raypak 336k BTU low nox RP 2100 gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump, diy control and automation system
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater, diy control and automation system
    Apr 2013
    Sacramento, CA
    2,769
    I do not see a problem here.
    Run the trench from the equipment pad to the back fence, along the fence, up the side fence and to the slide location.
    They take a bunch of water so you may need to dial down the other returns.
    Connect the line to the return header (if you have one) with a Jandy Valve.
