Thread: Stenner Pump - Econ Series
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    261
    Hi All,
    I've been considering whether to get a Liquidator or a Stenner Pump. After careful thought, I'm leaning towards a Stanner pump due to the more precise injection of chlorine. The Econ T model looks especially good as it contains a timer, which means one less item (timer) that I have to purchase and mount.
    I've read some threads mentioning that the Stenner Econ T model is for INDOOR use only. In looking at Stenner's website, it appears that it is rated for INDOOR/OUTDOOR. Am I missing something here, or perhaps this is a newer verison of the Econ T??
    http://stenner.com/products/pumps/econ-t-series
    PS: I've come up with some pros and cons to the Stenner VS Liquidator, in which I'd love to get more feedback.
    Liquidator
    Pro - Less $$, No electrical, Chlorine stays cooler (submerged in water...I live in PHX in direct sunlight)
    Con - Less precise, more cleaning, more failing parts
    Stenner
    Pro - Precise
    Con - Expensive, electrical concerns, chlorine degradation concerns (chlorine tank shielded, but still hot), motor failure is expensive
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
    22,703
    Re: Stenner Pump - Econ Series
    I think they upgraded the Econ T control membrane so it could be outdoor rated.
    May 2016
    Woodland, Ca
    235
    If you go the Stenner route, it won't take long to forget about the money spent. It is so nice to have the precision and reliability. I'm curious to learn more about the econ model, it doesn't seem to be much less than a normal model and I wonder what the trade off is?
    Do you have any sort of automation? Even for a novice like myself, I found it very easy to integrate into my existing automation.
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
