Thread: Backwash Help
    May 2017
    Honesdale
    1
    Backwash Help
    Is it normal when you backwash your sand filter to have dirty water coming out and back into the pool? Please help I just replaced the multiport and spring handle. Did I possibly put it on backwards please help
    May 2016
    West Bloomfield, MI
    757
    Re: Backwash Help
    No it's not normal. Did you rinse after the backwash and before setting it back to filter?
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Backwash Help
    Quote Originally Posted by Ronseth1234 View Post
    No.
    Before we start condemning the multiport valve, let's ask about technique. Did you backwash until the water looked clear? Did you set the valve to rinse afterwards? If either answer is no, then there was likely some dirty water still in the plumbing that just got pushed back into the pool, and I doubt you'll make that mistake again.
