Thread: Above Ground Bottom Track?
    May 2017
    New Jersey
    1
    Hello, I am in the process of installing a 15' round pool. I have the ground level. My problem is the bottom track and plate.
    The instructions state to put the track in 1/16th" before the stop which I did. When I finish the last track a bunch of the plates pop up. I have it round at 7.5 at every point. Is this normal for these plates to pop up like this and the wall will weight it down?
    Thanks
    22,703
    Re: Above Ground Bottom Track?
    Pictures would help, but sounds like it'll settle down once you set the wall.
