I have a Hydro Tools 8940 skimmer. It came with 2 gaskets. I keep reading I only use one, I just want to make sure before I do anything. My pool is full to where I want the skimmer. Any help would be appreciated. Thanks
Welcome to the forum.I have a Hydro Tools 8940 skimmer. It came with 2 gaskets. I keep reading I only use one, I just want to make sure before I do anything. My pool is full to where I want the skimmer. Any help would be appreciated. Thanks
swimline said:3. Skimmer Housing Installation procedure:
a. Select one of the 8905 hose adapters and screw into the bottom of the skimmer housing using the Teflon tape.
Caution, these are pipe threads and over tightening can crack the housing.
Never use any type of glue or sealant on these threads.
b. Place one of the 8946 skimmer gaskets on the 8919 skimmer face, making sure that the holes in the gasket align with the holes in the
skimmer face.
c. Align the skimmer face and gasket with the drilled holes in the wall panel and fasten with two pan head screws. These are the 2 short
screws in the 8947 hardware set. The holes are located on each side of the housing and are the middle hole in the set of the 3 holes
on the right and left sides.
d. Install the vinyl liner according to the swimming pool manufacturer’sinstruction. Do not cut any holes in the liner at this time. Fill the
pool to approximately 2" below the return fitting before proceeding to the next steps. Adjust the liner as necessary as pool is filling.
e. Align the second 8946 gasket and face plate and fasten tightly to the skimmer face with the 10 remaining stainless steel Philips
head screws.
f. You should have a sandwich of materials between the face plateand the skimmer housing as follows: the 8919 Face plate, 8946
gasket, the vinyl liner, the metal wall panel, 8946 gasket and finally the skimmer housing.
g. Connect the filter hose on the suction side of your filtration unit to the 8905 hose adapter on the bottom of the skimmer housing. Secure with a hose clamp.
Cut the vinyl liner along the inside edges of the face plate with a razor blade or sharp knife.
