Results 1 to 17 of 17
Thread: Pouring Chlorine
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Pouring Chlorine
    I am sure there are about a thousand posts on this, but when I joined it was not clear.
    Pouring chlorine. We need to do it slowly. But how slow?
    You do not want the bottle to "gurgle" when you pour. That means you have left no air gap, and it will splash.
    IMO, the perfect pour is like pouring crisco oil, no gurgling and no splash. But it does not splash because you have left an air gap and it is silent. And it is quick! 20-30 seconds max.
    Well I should add, that is with your pumps turned on. Never want to add chems in stagnant water.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pouring Chlorine
    More here about adding chems to your pool.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Two minutes seems excessive. My arms are worn out. But not arguing, slower is def better.
    40,848
    Quote Originally Posted by MarkTX View Post
    There is what we say ... and then there is what we do in our own pools
    Apr 2017
    Binghamton
    61
    Interesting....why is slower better?
    ~22k gal (36' x16') IG concrete pool with vinyl liner.
    3/4 HP Hayward Pump. Hayward EC75A DE Filter
    Laars Lite 2 Heater. Taylor K-2006 Test Kit
    https://www.facebook.com/domenic.emi...09148469284789
    Binghamton, NY (Upstate)
    40,848
    Mixes better, does not settle against the pool surface potentially causing damage.
    DFW, TX
    24,974
    You can float the bottle in the water while pouring.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    there is what we say ... And then there is what we do in our own pools
    x 100
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    I have never added bleach and MA closer than 15 minutes apart.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I've never waited more than 5 adding them both, which is more often than not.
    Essential Links:
    40,848
    Quote Originally Posted by Patrick_B View Post
    Shhhhhhhhhh
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Ohh geez -- I've never given it the slightest worry about of creating free CL2 gas from dosing bleach and HCl too closely together. By the time I've tossed the bleach bottle aside and measured out a pint HCl, that acid is going in.
    Seriously, there's far more CL2 gas coming from my bucket of trichlor pucks -- I open that sucker up and there's a green haze in it and I have to immediately move away...
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Jan 2017
    Texas Hill Country
    139
    I usually add bleach to the spa overflow spillway while the water is running. The shorter fall reduces splashing and the side of the spa is conveniently located for resting the jug while tipping it. The churning effect from hitting the pool should disperse the bleach quickly enough.
    25k IG / Plaster / Built Jul'16 / Spa with Spillway into Pool / Originally filled with trucked in city water, maintaining level with rain water / Polaris 280 Sweep / Jandy Pro Series EPump a& CV 580 Cartridge Filter / Aquacal Heat Pump / AquaLink Control Panel w/PDA / TF-100 Test Kit / 2 Yellow Labs swimmin' all the time
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    That seems like a keen idea, good to know. But my spillover is flagstone, which I have been told can be discolored by bleach. But it does sound convenient and practical.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Extremely unlikely I think.
    Essential Links:
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Maybe unlikely, but someone here with 8000+ posts said otherwise, so can't be sure. Anyway, PERFECT weather this weekend here in TX Don't forget to call your moms, this is Mother's Day.
    Apr 2017
    Phoenix
    500
    If I'm being honest, I just pour it in. I have a measuring bucket that I pour my bleach in to make sure I get the correct amount, and then pour it in the deep end. I don't have a side return jet, but have my in floor jets running
    I have also poured it directly in the skimmer, but pouring it in deep end with pump on is easier for me.
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
