Thread: Losing water at corners of intex rectangular pool
    Hello all,
    I have the INTEX 16 ft x 8 ft x 42 in Prism Frame Pool and the pool loses quite a bit of water in the open corner area. Has anyone had any luck in fabricating something to fix this? I found an old post on this but it was in the wrong forum: Losing water at corners of intex ultraframe rectangular
    Thx!!!
    T
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,883
    Re: Losing water at corners of intex rectangular pool
    It sure looks like what you can do for cheap to fix that problem. I bet you could use just about any plastic tube from anywhere. Let us know how it goes.
    Kim
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,723
    You could also try some of that new flex seal tape at the corners.
    Love TFP? Become a
    TFP Supporter!
    Thanks guys. I will give either idea a shot. I was thinking this should be a common "fix" give the popularity of these pools. Thanks!
