Thread: Overflow water level correction
    May 2017
    Hocking Hills, Ohio
    7
    Rookie here, be patient. I need to drain my pool level due to rain. I know how to go to service mode and how to turn pump on; do I turn filter to Backwash, Rinse or Waste just to suck water out and put down the drain it is hooked to?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,241
    Re: Overflow water level correction
    JZ,
    Welcome to TFP.. A Great resource for all pool owners with flow issues...
    Use your waste setting..
    Does your pool not have an overflow pipe in the wall of the pool? Often at the water line with a little grate over it.
    Thanks for posting,
    May 2017
    Hocking Hills, Ohio
    7
    Thanks for the reply. Waste it is; but no overflow pipe.
