Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: SLAMing chemical results first day
    Jun 2016
    Farmington KY
    23
    Hi all, so I started a SLAM on our pool this morning, added chemicals and have gotten the below results this evening:
    Now Goal
    FC 29 20 (SLAM level from this morning calculations)
    pH 8 7.5
    TA 80 65
    CH 125 150
    Cya 30 40
    CC 1.5
    When I entered into Pool Math it says I need to add Stabilizer and Calcium chloride...no more bleach obviously. Do I add all the extra chemicals during a SLAM? First time pool, first time messing with chemicals and a green pool! TIA!
    Owner build Fall 2016, L-shape inground vinyl 20x45x36 40,000 Gallons, TF-100 kit, from Western Kentucky
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Re: SLAMing chemical results first day
    Hi there
    Based on the information provided above, you don't need to add anything just yet. If you are slamming to get a green pool cleared up just focus on chlorine until it's clear and not the other numbers. PH test gets wonky results with FC above 10 so you can't trust that now anyway.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    Farmington KY
    23
    Yay! I was hoping someone would tell me that! I don't have any other chemicals on hand at home and would have to make a trip to town this evening So, I'll test again in the morning and add bleach if needed again to get to that 20 FC SLAM level from earlier or do I recalculate the the FC level because my cya actually dropped from 50 (this morning) to 30 this afternoon?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Quote Originally Posted by Vangar2012 View Post
    CYA is not a chemical that gets consumed in your pool. The ONLY way it could go down like that is if you drained a lot of water and replaced it. I suspect testing error on the CYA. The test is one that takes getting used to and the lighting is important. You should be in full sun to test with your back to the sun. Also it's not a perfect measurement since it's so subjective. I reccomend rounding up........so if the dot disappears at what looks to be 35 then assume it's 40.
    Hope that helps. You don't really want to raise CYA during SLAM Anyway as long as you have some.
    Jun 2016
    Farmington KY
    23
    Gotchya I didn't know that about testing with back to the sun. Thank you for the help!
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    No problem. You are on the right track with a good test kit. Don't hesitate to ask questions and one day all those chemical detail will click like a light bulb coming on.
    Since you're slamming a green pool, please be sure to brush frequently, no less than once daily. If you try to take shortcuts on SLAM you will find yourself chasing the green monster later in the season.
    Ask me how I know
    Jun 2016
    Farmington KY
    23
    Can someone take a look at my SLAM results from this morning? This is day 3 of SLAM and I can't tell any difference in our green pool Pool math says to add some calcium chloride and stabilizer, which earlier in the week it was advised to wait on the other chemicals. So I just wait and test throughout the day and add bleach with the FC gets below the 12 SLAM level? (I tested every 2 hours yesterday and brushed the pool twice, it wasn't until 4:00 in the afternoon did the FC slip down and I added a little bleach (2 bottles i think it was). I guess I feel like I'm not doing anything but watching a green pool! Is this typical take this long? Or longer?! lol) THANK YOU IN ADVANCE!
    Now Goal
    FC 17 5 (normally) 12 SLAM level
    pH 7.5 7.5
    TA 70 65
    CH 125 150
    Cya 30 40 (the 30 gave me the SLAM level of above FC 12)
    CC Forgot & dumped the FC vial
    30,941
    During a SLAM, we suggest you not waste time testing CYA, pH, TA, and CH. It doesn't matter. Your CYA is not bouncing like you think.....leave it alone.
    Your focus needs to be on keeping your FC right up to the max SLAM level or a bit more every time you test.
    Not enough to do?
    Brush the pool.
    check your filter psi.....has it increased by 25%? Time to backwash/clean.
    Vacuum or run your auto-vac
    Dec 2009
    Virginia Beach, VA
    135
    Just like Aimee said, right now the only thing you need to be worried about is FC. During a SLAM don't even bother measuring the other stuff, it's just a waste of reagents. Your CYA is exactly where you want it to be right now. 30-40 is your happy spot. All your other numbers look great, I wish I was where you are (going to start SLAM in the next day or two).
    Also, don't add calcium to a vinyl liner pool unless it gets down to like 50 or so. Calcium is more important for fiberglass or plaster pools, not so much for vinyl unless you get down super low - SEE HERE. I haven't added calcium in years.
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    Jun 2016
    Farmington KY
    23
    Thank you! I will stop testing the other stuff in the pool Newbie over reaction! I will brush, brush, brush today! I'm running the auto-vac during the day. I don't know much about the filter psi...I'll be honest, I was just backwashing it every couple to 3 days. I'll read up on here about that. I SO appreciate the help! Have a great Wednesday!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    What type of filter do you have?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2016
    Farmington KY
    23
    Sand filter. A big one, 30".
    This pic is today, day 4 of SLAM and it looks like day 1 still.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    So with a sand filter you want to hold off backwashing until your pressure is 20-25% above your clean pressure.
    How often are you testing and redosing?
    Be sure to brush and vacuum. Also, have you made sure that all debris is off the bottom?
    How does it look today?
    Jun 2016
    Farmington KY
    23
    I am testing about every 2-3 hours. I'm running our auto-vac all day, off at night. I'm brushing it every day, but maybe i'm doing it wrong or not brushing hard enough. I didn't think brushing would hard to figure out lol. No debris in the bottom. We do have seed squiggly things falling off the trees constantly so I am cleaning the skimmers every time I test (2-3 hours). I didn't know what our standard pressure on the filter was so I backwashed/cleaned it and its registered at 20 psi and that hasn't changed in a couple of days. Would adding DE to the sand help? I'm kinda at a loss. It really hasn't changed in color at all and this is Day 4. I keep looking at my numbers thinking I'm doing something wrong. Hubby is threatening to go to the pool store :0
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Have you been taking pictures each day? If not, you might want to do that. It's amazing how hard it is to see progress when you are looking at it all the time. But looking at a pic from even 1 day ago can really show you what is going on.
    30,941
    Do not add DE. It's too early in the process. Keep your FC up. On day 4, there is really no need to check FC more than about 2-3 times daily.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    How much FC loss are you seeing between testing?
    Jun 2016
    Farmington KY
    23
    I haven't been taking pics. The pics I took this morning I sent to hubby because he's been out of town since Sunday...he even said "looks like it did when I left!"
    I'm not seeing much FC loss during the day. I haven't really added much bleach this week. We've been cloudy with low temps this week and rain last night and today (don't know if that effects FC.)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Then Dave has it right. You don't need to test as often, once the loss between tests tapers off. What FC are seeing when you do test? Keep at it. Make sure you are getting everything with the brush. Check inside the skimmers.
    Might as well post that pic, that way we might spot some thing.
  20. Back To Top    #20
    30,941
    How much is that? We like to see the accurate FC results and when you took them so we can get a feel for how much total FC you are losing. Can you post your last several test results and when they were done?
