Thread: Help! I need dimensions Intex easy set 18' x 48"
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    130
    Don't have pool up yet. My plan is to set it up and leave it. I am putting billboard vinyl under the pool. For the inflatable ring, I am going to put packing peanuts/shreds instead of air. My problem is--mine is not up. I need to know the circumference of the top ring when inflated. I can guesstimate how far around (56'). So...if anyone has theirs up, could you measure and let me know.THANKS
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Help! I need dimensions Intex easy set 18' x 48"
    No clue, but I'll give you a and hope someone who knows will answer. You might also use the search box for easy set and send PMs to people who have one and who have posted recently. Or.... if you got impatient, answer your own question in the event someone else searches for the same answer in the future.
    Jun 2016
    Amarillo TX
    130
    As close as I can estimate, using dimensions on original box, The diameter is between 7 & 8 in. Then using the diameter shown on diagram, I am estimating that it will take about 15-17 cubic feet of packing peanuts to fill.
    Jun 2016
    Amarillo TX
    130
    I ordered 20 cubic feet. Hoping to be swimming by this time next week.
