Thread: Skimmer installation problem
    May 2017
    Dowingtown
    2
    Skimmer Face Plate wont fit with Butterfly gasket thru opening in wall
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,753
    Re: Skimmer installation problem
    Pictures would be helpful.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2017
    Dowingtown
    2
    Skimmer installion problem
    Face plate doesn't fit with butterfly gasket
    Too tight
    Fits without the gasket
    22,704
    As Jeff eluded to, we need more info, Pictures would be most helpful, and type, size and model numbers may help also?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,015
    Re: Skimmer installion problem
    Can we have a little more detail please. Maybe even a picture or two so we can see what you are dealing with.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
