For the 10-minute drill, yes, I'm afraid so. Unless you can test, retest, and add bleach every 10-minutes in succession, you won't be able to neutralize whatever is in that water. It's good to see that "some" FC is trying to hold-on. That's reassuring. So perhaps once you get your new refills, the water won't be quite so stubborn, allowing you to breakthrough that barrier that will allow FC to hold closer to 10 so you can effectively start the SLAM.Does interrupting the process cause me to start over?
That's HUGE! If you test again and it's still there, you are now ready to begin the real SLAM. Although I suspect you're still waiting on reagents right? So technically you can't get accurate yet with the numbers. But continue to keep that FC between 5-10 as best as you can. Once the refills arrive, you'll be able to adjust FC to 12 and CYA to 30.Finally FC jumped from 2 to 8 ppm!!
tested again and it dropped to 6
Added more bleach to keep fc up
am starting to raise cya. how much time does it take to go from 0 to 30?
Bleach starts out alkaline but when it breaks down it ends up pretty much neutral. Try the search box for bleach pH neutral and read all about it.FINALLY!! CC down to .75 and holding. FC was 3 this morning (same as yesterday)
pH is 7.2 (had to raise it from the 6's). CYA 35, TA 250. Still slamming and trying to knock out the CC. Appreciated the pic of the Clorox truck. I am about 45 gallons into this thing. Pulled my light and found part of the problem.
Two questions.
What does it take to get to 0 CC and with adding as much bleach as I have why has my pH not risen? I have read that bleach raise pH.
Depends on how accessible they are and if water can get trapped inside. If you are able to look inside each item, I would. Losing 12-13 FC overnight is still a lot of FC consumption. Without any other items in the water that may hold algae, it could simply be a matter of consistency with maintaining the proper FC SLAM level. Try to maintain the FC level of 16 as best as possible, testing as much as needed to confirm.But have built in molded ladder and steps.
Not really. It's one thing to overshoot your FC target by 2-3 ppm, but going too high doesn't help the SLAM go any faster and is actually a waste of bleach since there won't be enough CYA to support it (UV protection).Does it do any good to raise the FC higher than what the chart says?
