Results 1 to 8 of 8
Thread: How to raise TA level properly?
    Dec 2015
    San Jose, CA
    31
    Hello
    In the PoolMatch tool, it only shows and calculates how to raise the TA level by adding baking soda. I have a bucket of ClearView_TA (please also see the attached picture), may I know how much I need to add to raise TA from current 30 to 60 (the ideal level)?
    Brand: ClearView_Total Alkalinity, 100% Sodium Hydrogen Carbonate.
    The latest water test:
    FC: 6
    CC: ~0
    PH: 7.4
    TA: 30
    Hardness: 20
    CYA: 45
    Thank you very much!
    Regards,
    Kevin
    10,200Gals, 10X34, 3'-4'4'' deep, rectangle in-ground vinyl pool; Solar cover;
    3/4HP Advantage pump; CC150 Pentair cartridge filter;
    NC22 SmartPool Smart-Kleen robot; and a 2-wheel PoolCleaner of HAYWARD
    Tailor K2006 test toolkit;
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,903
    Re: How to raise TA level properly?
    It's baking soda - It has multiple names:
    Baking Soda
    Bicarbonate, Sodium
    Carbonic Acid Monosodium Salt
    Hydrogen Carbonate, Sodium
    Soda, Baking
    Sodium Bicarbonate
    Yea, I'm serious - they used a fancy name to sell you baking soda in a fancy bucket at an inflated price.
    Use it sparingly, you only want to get up to 60.
    Support the site
    Dec 2015
    San Jose, CA
    31
    Thanks.
    But I like to know how much I should use. In the PoolMath tool, it only shows the result by using Baking Soda. My question is how much I should use this 100% Sodium Hydrogen Carbonate (Baking Soda anyway) to raise TA from 30 to 60.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    You put 30 in the "Now" column and 60 in the "Target" column and hover over the "oz" field and it says 4lbs 8oz for a 10.2k gallon pool
    Here's a screen grab:
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Huntsville AL
    39
    Clear View, Total Alkalinity
    $1.52 lb
    Active Ingredient - 100% Sodium Hydrogen Carbonate
    Arm & Hammer Baking Soda
    $0.63 lb
    Active Ingredient - 100% Sodium Bicarbonate
    For those keeping score Sodium Bicarbonate (NaHCO3) and Sodium Hydrogen Carbonate (NaHCO3) are the same crystalline chemical compound commonly known as baking soda.
    Moral of the story, stay out of the jewelry store, I mean pool store.
    15,000 gal In-Ground Vinyl, Jacuzzi Laser Sand Filter w/ 1.5hp Pump , Polaris Cleaner w/ 1hp Pump, Taylor K-2006-C Test Kit
    May 2014
    Franklin, NC
    9,903
    Quote Originally Posted by Mr. D View Post
    This is one of the tenets of TFP. There is almost nothing a pool needs that does not have a "generic" equivalent available in other stores. While there are good pool stores out there, many sell through fear, confusion and scare tactics.
    Support the site
    Dec 2015
    San Jose, CA
    31
    Thank you so much, guys. Appreciate your feedback!
    Apr 2013
    Austin, TX
    7
    Here in Texas, HEB sells their "Hill Country Fare" brand baking soda for just $0.49 per pound.
    20,000 gallons, in-ground, PebbleTec, flagstone coping. Rectangular, with in-pool spa and beach shelf.
