Results 1 to 7 of 7
Thread: New Raypack 106A
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    New Raypack 106A
    Well I bit the bullet and ordered a propane heater for my little pool. I chose the Raypak 105000 btu.propane as my pool is only 9 x 18. I currently have solar so this will hopefully be the best of both worlds.
    I have read about tank sizing and understand that bigger is better but I am worried that lifting a 100 will be too much. What about a combination of 40's tied together? Also is the installation something I can do myself? I plumbed all my solar and added all the controls so I'm fairly handy, I've just never dealt with a pool heater before.
    Hopefully it arrives for the next weekend!
    Rob
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: New Raypack 106A
    Not sure Rob, but we have a couple of good heater guys around. One of will hopefully pick this up pretty soon. If you PM ps0303, he can answer all this and more. Heaters are what he does.
    Essential Links:
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Awesome! Thank you Patrick. Heater arrives next week according to shipping. I have decent solar already, so I'm just looking to heat on those off days and in the evenings. Hoping to hit 70+ today!
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Sure you could do 2 40's. So you are going to buy the tanks but you want to be able to take them to get filled? You should be able to find a local propane company that will deliver the propane to your house and then you won't have to worry about carting the tanks to get them filled. If you get bigger tank(s), you won't have to refill often also. A 100lb or 200lb tank would be better.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    I just contracted a big tank for a year. Drop off, fill, regulator and hose for 700+ Canadian. We need a permit here for this size of taking so I am reaching out to any pipe fitters I know to work for beer!
    It's a lot of money, I hope it's worth it...
    Cheers,
    Rob
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    So my heater arrives on Wednesday, and my propane tank (420lb) arrives the following Monday. I have a couple of quick questions for the experts.
    I currently use a Suntouch to control my single speed pump and solar. The heater is analogue so from what I understand in this setup I would use the"firemans" switch on the heater to connect to the j12 jumper on the Suntouch board. Once it's connected how is it read by the touch? In my case I think I would use the solar preferred setting?
    When I plumb for heater it looks like my solar from roof would go into heater then out to pool and I would leave the existing solar valve and actuator in place and just adjust the return from solar. Is correct?
    Any advice would be great,
    Rob
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    UPDATE:
    Found older thread that deals with a lot of this.
    Wiring question: upgrading to a SunTouch controller
    Google is your friend!!
