Results 1 to 9 of 9
Thread: Hayward aqr15 questions
    Jul 2014
    Manhawkin/ NJ
    82
    I just hooked up my aqr15 my pool is about 17000 gallons. I have a pentair vs pump. Is seeing up the run times for the swg all just trial and error or is there some type of equation to figure out how long and what speed to run pump and what percentage to set swg to.
    Oct 2015
    San Diego, Ca.
    801
    Re: Hayward aqr15 questions
    Mostly trial and error. Try 100% for 5 hours. Pump speed won't matter.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Jul 2014
    Manhawkin/ NJ
    82
    OK thanks set it to go on for 5 hours tomorrow, then I just check the Fc to make sure it's where I want it and adust each day until I get it? Also is it normal for the no flow light to blink on start up for about 30 seconds?
    Oct 2015
    San Diego, Ca.
    801
    In my area, we keep the SWG @ 100% and adjust the run time to control the FC output. I log the run time and FC on a calendar so I know next year where to set the timer for each month (December = 3 hours and August =18 hours on mine).
    Yes on the Flow Light.
    P.S. The speed on the motor is irrelevant in regards to the SWG producing FC. It just need enough to keep the flow light green.
    Jul 2014
    Manhawkin/ NJ
    82
    OK thanks, I'm in nj so only have to pool open 4 or 5 months. Is there any advantage or disadvantages to running higher percent less pump time or lower precent longer pump time?
    YetiAsr's Avatar
    Dec 2016
    Pflugerville,Tx
    70
    I run my SWCG at 20% with a VS pump running for 7hrs at 60%, I personally would rather slowly introduce chlorine into my pool, I know there are many people here that run for 24 hrs at 1200 rpm so they are always introducing chlorine .
    BTW this keeps my chlorine locked at 5.5 ppm, I'm shooting for 5-6
    31x22 FF IG, 16k gallon , 3.5-5.5-4.5, Hayward 425 cartridge, Tristar variable speed, Aqua Rite AQ15 SWG, HPC 4 wireless controller, LED, Texas Grey pebble finish, Taylor K 2006 and 1766,speedstir ,New build in central Texas....
    Jul 2014
    Manhawkin/ NJ
    82
    Last question I hope does any one else instant salt read 0 after it has been running for a little while?
    Mar 2017
    League City, TX
    28
    Quote Originally Posted by kevgle4587 View Post
    Asked this a while back too. If the SWG isn't generating, it will not show a salt reading. So at 50% you'll see the reading for 30 minutes of each hour and no reading the other 30 minutes.
    Chris
    17k IG plaster, Pentair FNS DE, Aquarite 40k SWG, & Polaris 380 (AKA "Jacques") using city water
    Jul 2014
    Manhawkin/ NJ
    82
    Great, thanks alot. I bought the system from amazon warehouse like new never used but still nervous. Looks like it's working perfect so far
